bore and it's effect on CR
Old Feb 28, 2003 | 06:52 PM
  #26
texan's Avatar
Default Re: bore and it's effect on CR (civicdream)
ok, the air/fuel ratio will remain the same. I understand that. But you are taking more of the air/fuel ratio and compressing into the same amount of area. So the molecules will be closer together causing a greater explosion??? Is this less dense or more dense??? I get them confused.
More dense. How old are you? Also it's not explosion we are looking for, it's combustion. Combustion = controlled expansion, which is something we can harness to perform work. Explosion = uncontrolled expansion, which is something that breaks parts. Detonation is explosion of all or part of the mixture.
whathonda- That's right, it's called quench area (also called squish area). Helps in detonation tolerance, and is definitely important to chamber dynamics.
Old Feb 28, 2003 | 07:37 PM
  #27
Bailhatch's Avatar
Default Re: bore and it's effect on CR (texan)
So this design in an NA setup could actually let you run a slightly higher compressing ration? or would the difference even be worth calculatiing?
I suppose the same would be true for FI motors too. letting you run more boost, timing or whever other variables there are in determing detonation resistance. If it's even worth factoing in, what do you think Texan
Old Feb 28, 2003 | 08:56 PM
  #28
civicdream's Avatar
maybe I am blowing this way out of proportion, but what the hell is that supposed to mean????? I hope this was in no way an insult to my intelligence. This your world that I am trying to learn. Step into a field where I possess great knowledge, and I might be asking you the same damn thing.
Old Feb 28, 2003 | 09:40 PM
  #29
texan's Avatar
It was a simple question. I haven't met anyone that didn't know what density meant before, so I thought perhaps you were quite a bit younger. Why would I insult you after being patient in explaining something to you?
Old Feb 28, 2003 | 09:42 PM
  #30
J2turbo21's Avatar
Exaclty,i dont think he meant anything by it.He took the time to repeat what he said to in different ways and was always polite.You my friend are ungrateful.
Old Feb 28, 2003 | 10:12 PM
  #31
texan's Avatar
Default Re: bore and it's effect on CR (whathonda)
It's not so much an effect that's calculated into chosen c/r, it's just something you try to maximize in any given chamber. There are way too many dynamic things going on in a cylinder for enthusiasts like us to be able to draw simple mathematical conclusions from, but it's safe to say that more quench when possible is always a good thing. This is why DPR always welded up their chambers and made a cloverleaf shape. Also note that in order for quench areas to work properly (quench not only helps mixture homogeny but also helps to cool the piston), the tolerance between the piston at TDC and cylinder head mating surface needs to be very small. If you take KB Piston's advice, they claim the effect loses most of it's anti-knock properties above .06".
Old Feb 28, 2003 | 10:24 PM
  #32
Cuong-nutz's Avatar
It's not so much an effect that's calculated into chosen c/r, it's just something you try to maximize in any given chamber. There are way too many dynamic things going on in a cylinder for enthusiasts like us to be able to draw simple mathematical conclusions from, but it's safe to say that more quench when possible is always a good thing. This is why DPR always welded up their chambers and made a cloverleaf shape. Also note that in order for quench areas to work properly (quench not only helps mixture homogeny but also helps to cool the piston), the tolerance between the piston at TDC and cylinder head mating surface needs to be very small . If you take KB Piston's advice, they claim the effect loses most of it's anti-knock properties above .06".
could you elaborate on that area. I'm not getting the picture.
Old Feb 28, 2003 | 10:30 PM
  #33
texan's Avatar
Default Re: bore and it's effect on CR (Cuong-nutz)
The distance between piston crown and cylinder head. Quench area is where the flat portions of both come very close to one another, forcing air from that area towards the center of the bore and creating strong turbulence (as well as making that portion of the chamber run a bit cooler than the rest).
Old Feb 28, 2003 | 10:54 PM
  #34
Cuong-nutz's Avatar
Oh, the diameter on the head is smaller than the bore on the block. Thus, there is a quench area in between.
edit: what's valve relief?
[Modified by Cuong-nutz, 1:56 AM 3/1/2003]
Old Mar 1, 2003 | 06:57 AM
  #35
Bailhatch's Avatar
That makes sense to make the quench area very short (less than .06")so that the air is forced out with more pressure thus creating more turbulance.
Just to clarify for me, the headgasket is sized to the bore of the cylinder, right. If the edges hung out into the combustion chamber woulden't they actually create hot spots? making that cylinder more prone to knocking? What about filling the chamber like you were talking about texan. Woulden't that create hot spots on the edges since they 'stick out' more. Or are the edges rounded over? I bet you could really raise your compresion ratio by making that clover leaf design. Do poeple do this on B series heads?
Old Mar 1, 2003 | 11:34 AM
  #36
civicdream's Avatar
Ok, so i blew it out of proportion, but you are wrong. I know what density is, I just don't know if you say "more dense" or "less dense" when molecules are closer together. Easily confused, besides science not my thing. HOWEVER, I am very appreciative of Texan's time and patience on this subject. He was a great teacher. By the way, I'm 21. All you had to do was click on my name, and it will tell you. Later. and no harm done.
Old Mar 1, 2003 | 12:52 PM
  #37
3rdGteg's Avatar
I was thinking about trying that out myself on a spare b16 head I have laying around. I wonder what type of welding to do this; heliarch or what?
mr_munro
Jun 7, 2012 10:34 PM
B18 CYA
11
Jul 28, 2006 06:24 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
4doorH22
Sep 7, 2001 08:29 AM
4doorH22
Sep 7, 2001 06:01 AM
