Boost creep from HELL!!
Old Jan 31, 2007 | 11:44 AM
faSHOwidIT's Avatar
Default Boost creep from HELL!!
So i was cruisin around today and decided to get on it. I did a 4th gear roll and next thing you know my boost guage goes pass 20!, i look at the peak on the boost controller it said 25lbs. I got a 14lb spring in the wastegate but on the dyno is would creep to 16lbs. So i turned the boost all the way down to zero on the boost controller and it'll creep to 17lbs. What should i check for besides leaks on the vacuum lines? Boost controller i'm using is, Blitz SBC-ID, wastegate is tial 44mm. Peakboost ramhorn manifold. since i lowered all the values on the boost controller and it didnt jump to 25lbs, im guessing the boost controller is at fault?
Old Jan 31, 2007 | 03:59 PM
gsp ej1-em1's Avatar
Default Re: Boost creep from HELL!! (faSHOwidIT)
Try tightning all the bolts and nuts to the wastegate and manifold. Last time my manifold was loose. My boost jumped to 25lbs.
faSHOwidIT
Jan 31, 2007 03:51 PM
playahwitgame
Sep 19, 2006 09:08 AM
Mad Cow
Feb 24, 2005 06:12 AM
GDM Z28
Nov 30, 2003 06:13 AM
