the bolt is Round!
Old Feb 3, 2003 | 01:36 AM
d0nkeyxPunch's Avatar
Banned
Default the bolt is Round!
the bolt looks like this O how do I get it off actually it looks like this D after we used the vice grip anyone know of a place in the torrance area where we can get this drilled off or taken off by hulk hogan??????????????
Old Feb 3, 2003 | 01:40 AM
XxDemonxX's Avatar
Default Re: the bolt is Round! (EM1b16a)
man what in the **** are you talking about, ****......try ur teeth, i promise it will work
[Modified by XxDemonxX, 10:40 AM 2/3/2003]
[Modified by XxDemonxX, 10:41 AM 2/3/2003]
Old Feb 3, 2003 | 09:38 AM
Horatio's Avatar
Where's it at? I just had the same problem with a lugnut on my truck and to get the sucker off there, I just hammered a lug wrench into it and twisted it free. I got off lucky , I think. If you give more info, we might be able to help better.
Greg
Old Feb 3, 2003 | 10:45 AM
rotten's Avatar
Just weld another bolt to it, and twist it off that way.
Old Feb 3, 2003 | 02:32 PM
kyle h.'s Avatar
Default Re: the bolt is Round! (rotten)
keep spraying it down with lube and keep using the vise grips
Old Feb 3, 2003 | 02:50 PM
91DA9's Avatar
Default Re: the bolt is Round! (kyle h.)
That depends on what bolt you are trying to take off.
I have had a head stud stuck before. I used a cut-off wheel to form a "new" bolt head. I then hammered a socket onto the "new" bolt head and twisted it off. It only works if you have enough room to work with the cut off wheel. A Dremel tool will work also
Old Feb 3, 2003 | 05:00 PM
Lord Helmet's Avatar
You know at Sears they sell this tool called "bolt extractor" for about $20 I think? and it's designed for removing rounded off bolt heads. it has left handed threads inside it that will "bite" into the rounded head and remove it. it's kinda similar to a screw extractor. hope that helps.
Old Feb 3, 2003 | 05:08 PM
Kamin's Avatar
Default Re: the bolt is Round! (sleeperciv)
and if you dont want to buy somthing
get the next 1mm lower sized socket and hammer that **** on.
Old Feb 3, 2003 | 06:06 PM
ULTRA911's Avatar
we have to know what type of bolt and the location of it.
Old Feb 4, 2003 | 01:49 AM
Banned
Default Re: the bolt is Round! (ULTRA911)
Thanks for the helpful advices guys....I FINALLY got that sucker out! I used some WD40 and some heavy duty (I call it "delux") vice grip to get it out.
kyorishin
Apr 11, 2006 11:02 PM
.M.
Mar 29, 2004 10:48 AM
Phat Corolla
Jan 3, 2002 07:35 AM
Zulu888
Nov 14, 2001 04:11 PM
