Bolt Grade Bolt Class
Old Apr 29, 2005 | 07:23 AM
pdiggitydogg's Avatar
Default Bolt Grade Bolt Class
Its time for me to build the b18b and Im looking for bolts to hang it on the stand.
I need M12x1.25 (correct?)
All bolts that I find that size are only Class 8.8 and Im remembering that is equivilent to sae Grade 5...
The correct grade is class 10.9, correct?
(Metric does not come in Grade 8 guys)
The engine will be sitting on the stand for a LOOONG time as I can only afford to build it slowly. Should I keep looking for class 10.9 or will 8.8 be enough??
(Ive tried McMasterCarr and they only carry 10.9 M12 in 1.75 thread...where else can I look (tried ho depot, ace, autozhit)
Heres a damn picture so people look
Old Apr 29, 2005 | 08:17 AM
MadtownSi's Avatar
Default Re: Bolt Grade Bolt Class (pdiggitydogg)
You are correct, 10.9 grade metric fasteners are high strength steel equivalent to Grade 8. I believe they should have a “10.9” stamp on the head of the bolt. As for bolting the block to the stand, I just used the transition mounting bolts.
Old Apr 29, 2005 | 08:20 AM
95accordsir-t's Avatar
are u going to have the head and alternator and all of the weight on the stand also?
or is it just going to be the block.
im not sure wat i used but im thinking they were 8.8, and i had an entire 1.5 liter hanging on there with a/c compressor and all and it held the weight.
Old Apr 29, 2005 | 08:53 AM
Right now its a complete short block
Old Apr 29, 2005 | 09:38 AM
Honda Hick's Avatar
I've just used the transmission bolts or really any larger high grade bolts that fit through the transmission mounting bolts. They don't necessarily have to be metric bolts because you aren't actually bolting into the block. ****, I used 4 8" construction lag bolts to hold my B18C on over the winter. I wouldn't worry about it too much, I mean when you yank the motor/tranny out of the car you are just holding it up by a ~3/8" bolt on the driver's side.
Modified by Honda Hick at 2:07 PM 4/29/2005
Old Apr 29, 2005 | 09:42 AM
Default Re: Bolt Grade Bolt Class (Honda Hick)
yea i say if u have the tranny bolts to go with them cause they are extremely strong anyways
Old Apr 29, 2005 | 10:17 AM
No tranny bolts...its my first Bseries and all I have is the block
Old Apr 29, 2005 | 11:13 AM
Default Re: (pdiggitydogg)
hummm.....
wish i could think a little better right now but im sure someone will tell u something soon its actuall an easy solution ... dohgh!
Old Apr 29, 2005 | 11:31 AM
well I bought some class 8.8's
I'll jam a 2x4 under it too
Old Apr 29, 2005 | 02:31 PM
that should do
good luck with ur build
Old Apr 29, 2005 | 07:12 PM
MightyMouseTech's Avatar
Default Re: (95accordsir-t)
It is only a Honda engine, they don't weigh anything (in the world of motors anyways) don't worry about it.
Plastic bolts would probably be strong enough............
Old Apr 29, 2005 | 10:31 PM
SLOW EF8's Avatar
Just got to any hardware store and ask them for Grade 8 bolts, that would be strong enough.
BoostinEJ1
41
Apr 16, 2006 01:18 PM
shorto85
Feb 20, 2006 11:39 AM
Matgallis
Aug 25, 2004 02:36 PM
B18EG6
Feb 19, 2003 02:33 PM
