blown HG??
Old Feb 23, 2006 | 09:14 PM
Honda Sport's Avatar
Default blown HG??
my friend just finished installing his motor. one of the JDM "30-40K km" motors. anyways, it sounds like a WRX. doesn't sound right.
anyways to my point. he finishes everything off. when he drives it around, there's a lack of power. no CEL's. just did a tuneup consisting of new plugs, wires.
reason why I suspect a blown HG is cause when I went to feel the coolant hoses, they were VERY hard. felt pressurized. so I'm think it's a blown HG, cracked head, sleeve.
let me know what you guys think. TIA.
Old Feb 23, 2006 | 09:57 PM
mstolars's Avatar
Default Re: blown HG?? (Honda Sport)
Make sure you put the plug wires on right and the injector clips are on the right injectors, sounds like a misfire possibly. Hard coolant hoses is usually normal, the radiator pressure cap doesn't open till after 10psi of pressure in there. Do a compression test too, that will tell you for sure if there is a blown HG. Good luck
Old Feb 23, 2006 | 11:41 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: blown HG?? (mstolars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstolars &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you put the plug wires on right and the injector clips are on the right injectors, sounds like a misfire possibly. Hard coolant hoses is usually normal, the radiator pressure cap doesn't open till after 10psi of pressure in there. Do a compression test too, that will tell you for sure if there is a blown HG. Good luck </TD></TR></TABLE>
I agree. Double check your connections and plug wires.. timing sounds off or its a misfire.
Old Feb 24, 2006 | 11:18 AM
I TRIPLE checked my firing order. it's correct. new plugs, new wires. injector clips are correct.
I've never seen ANY car with as much pressure buildup in the coolant hoses as my friend's.
Old Feb 24, 2006 | 12:52 PM
mstolars's Avatar
Default Re: (Honda Sport)
You could pull the radiator cap when the car is cold and start it up, if it starts bubbling and gushing fluid, that's a sign of a blown HG. Or, just do a compression test to know for sure, you can get a loaner compression tester at just about any autoparts store.
EDIT: Also, check for vacuum leaks too.
civic_dork
Apr 24, 2019 04:01 PM
gurlugotmilk
Honda S2000
Feb 23, 2009 08:26 AM
Honda Sport
Feb 24, 2006 11:22 AM
ham
Dec 28, 2005 08:11 PM
WestEM1
Sep 23, 2005 08:34 AM
