Blown B16! What happened?
My engine just blew up, it started to burn antifreeze (white smoke) and then I felt a significant loss of power. When I got home I sprayed water on the exhaust ports and #1 is cooler that the other three. What happened? I did not hear any load noises and there is no knocking sounds like when a connecting rod snaps. Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Blown head gasket. </TD></TR></TABLE>
thats what it sounds like..
take out the spark plug, inspect, also look inside the bore when the piston at tdc.
if your hg. blew like that that cyl. should be clean as so the srapk plug
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Blown head gasket. Check your compression. </TD></TR></TABLE>
I would also agree that the head gasket blew out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF7 »</TD></TR><TR><TD CLASS="quote">I removed the spark plugs and all four are black; i looked inside the piston at TDC and it is not clean either. I am going to do a compression test.</TD></TR></TABLE>
Instead of a compression,do a leak down. Warm vehicle to operating temperature. Then when warm set each cylinder at TDC and apply psi to the cylinder. Make sure the radiator cap is off and radiator topped off. A blown headgasket will cause to coolant to rise out of the radiator. This pinpoints the bad cylinder and verifies the problem a 100% of the time. Good luck!
EG2Driver
Sep 4, 2006 07:35 PM
