block balancing
Old May 8, 2002 | 03:58 PM
integRated109's Avatar
Default block balancing
my engine went to the machine shop today. i have darton sleeves(closed deck design) je pistons and eagle rods, and ARP head studs going in. the owner told me i have to get the block rebalance after the sleeves go in, but he doesnt do it. i was just wondering what is involved in block balancing, and any cost estimates?? thanks
Old May 8, 2002 | 05:11 PM
earl's Avatar
Default Re: block balancing (integRated109)
I never heard of block balancing. You can get the pistons and rods balanced or just the crank balanced (best idea) but how or why could you spin your block fast enough to ever try to balance it?
Old May 8, 2002 | 07:29 PM
rainforest's Avatar
Default Re: block balancing (earl)
only rotating mass is balanced.
Old May 8, 2002 | 08:56 PM
1 2 NV's Avatar
my motor just got balanced. a proper balance job is the lower rotating mass, that includes the crank, rods, rod bearings, pistons, piston rings, flywheel AND clutch. u can b assured all my stuff was there.
Old May 8, 2002 | 09:49 PM
Rocket's Avatar
Maybe the word "rebalance" should be "resurfaced". Makes sense. If so then you are looking at $25-$35 for a clean-up pass.
TcUiRvBiOc
May 16, 2007 01:29 PM
B18C1CYA
May 22, 2005 09:05 AM
tegasaurus
Jun 10, 2004 01:49 PM
qqqq
Apr 28, 2003 04:41 PM
