bleeding clutch master and slave cylinder..
Old Jan 9, 2003 | 10:36 PM
Lei Siew Long's Avatar
Default bleeding clutch master and slave cylinder..
do i leave the car running like i do when i bleed the brake system?
Old Jan 10, 2003 | 03:15 AM
blueeg's Avatar
Default Re: bleeding clutch master and slave cylinder.. (boostedeg6)
i never had the car running when i bleed my brakes. stops good.
Old Jan 10, 2003 | 06:09 AM
Default Re: bleeding clutch master and slave cylinder.. (blueeg)
when i bleed the brake system with the car off, little bubbles ALWAYS appear out of nowhere no matter how many times i bleed and bleed. when the car is on, the air bubbles aren't an issue because after 3 bleeds for each caliper and they're gone. just wondering if the same applies to the clutch master and slave cylinders
Old Jan 10, 2003 | 06:19 AM
Gus's Avatar
Gus
No, you do it with the car off. The reason bleeding the brakes with the car on probably worked better for you is because of the brake booster. The clutch system has no power assist system. You could have the engine running, but it won't do anything to help.
boostedrust
Jul 15, 2014 08:15 AM
s13hero
Oct 13, 2010 02:33 PM
autoxthis
Aug 21, 2008 08:23 PM
PapaRoach736
Mar 1, 2003 07:25 PM
