Best value engine for EF swap
Old May 31, 2009 | 01:18 PM
Eighty-Nyne's Avatar
Default Best value engine for EF swap
I'm looking for the best overall value.
performance
driving experience
budget
etc.
I'm really undecided.
Old May 31, 2009 | 02:28 PM
Charlie Moua's Avatar
Default Re: Best value engine for EF swap
good question but all too common
your going to have to decide for yourself.
Everyone does not have your budget, hp goals, powerband desired, ect.
Most will say B16 for budget and everyone would love to get a k swap.
Old May 31, 2009 | 02:48 PM
fatboy1185's Avatar
Big Cat
f20b
Old May 31, 2009 | 07:31 PM
stevenDAtegra's Avatar
LS Swap with a b16 tranny is a good start. Or you can get an ls and keep the tranny and go boost later on. There aren't any gsr cable trannies with the ratios people think of with GSRs unless you swap the gearsets into a 92-93 cable transmission casing
b16 swaps are too common for budget ef's and an ls with a b16 tranny usually has the advantage
Old Jun 1, 2009 | 04:25 AM
gibsanez's Avatar
What does this mean? I have a stock 92-93 GSR YS1 transmission with ultra short gears, and they weren't swapped in, they're oem stock for that transmission.
Old Jun 1, 2009 | 06:20 AM
The YS1 Cables trannies had real close ratios to the b16, if not identical. I'd check it right now but am about to head out but maybe the final drive is just a bit different? The B17 ys1 is preferred over b16 but still is very close
Old Jun 1, 2009 | 07:11 AM
mj91ef9's Avatar
CHECK MY THREAD, It will answer your ?s. LS/VTEC with 92/93 YS1 tranny and yes the gears are shorter than the newer GSR tranny, Couple places you can find the info on web and the Final drive is 4.4
Old Jun 21, 2009 | 06:36 PM
spooledinurface's Avatar
X2
punxsk8r555
Transmission & Drivetrain
Nov 29, 2010 04:07 PM
wakaranai
Oct 31, 2009 04:19 PM
BuBBa y0!
Dec 17, 2003 11:55 AM
BuBBa y0!
Dec 16, 2003 07:13 PM
