Best Motor?
Old Jun 19, 2006 | 08:27 AM
vtecstudent's Avatar
Default Best Motor?
Wats the best motor to do ur first engine build on? that u can also get some pretty good power out of? and where also could i find this motor? meaning year make and model? thanx guys!
Old Jun 19, 2006 | 10:53 AM
gmadsen100's Avatar
price range?
Old Jun 19, 2006 | 11:30 AM
Default Re: (gmadsen100)
total = $5,000 - $7,500
Old Jun 19, 2006 | 01:15 PM
Default Re: (vtecstudent)
Old Jun 19, 2006 | 02:11 PM
TunerN00b's Avatar
Default Re: Best Motor? (vtecstudent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecstudent &raquo;</TD></TR><TR><TD CLASS="quote">Wats the best motor to do ur first engine build on? that u can also get some pretty good power out of? and where also could i find this motor? meaning year make and model? thanx guys!</TD></TR></TABLE>
C32B
Old Jun 19, 2006 | 02:49 PM
Default Re: Best Motor? (TunerN00b)
maybe i could also afford the car too!!!! lol
Old Jun 19, 2006 | 03:40 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecstudent &raquo;</TD></TR><TR><TD CLASS="quote">maybe i could also afford the car too!!!! lol </TD></TR></TABLE>
And the answer of "what engine" is best answered if we knew the chassis its going into, what you mean by "build", and what your intended use of the car is. Integras come with B series, and thats probably the easiest to put back into them. 96-00 Civics should take a B with just Si motor mounts, but you shouldverify that first. B16s are nice and cheap. If you already have an H powered Prelude or Accord, might be easiest to drop another H in it. There is a ton of information on both engines, to make your build easy enough, unless you intend to do something radical. Both can make good power.
And then there's always the K series. They seem to really like bolt ons, but are a relatively new thing, in terms of a total build. There's info out there, and on this site, for them, just not as much. They'll also be more expensive.
Either way, throw out alot more information if you want help. Can't ask such a generic question and expect to get any useful information.
Old Jun 19, 2006 | 03:50 PM
boost_lee's Avatar
****, if you got 7,500 to spend, go Diff from all ricers and go k20.
or do a b18c5 (type-r) All motor, or Forced induction build :D
Old Jun 19, 2006 | 06:54 PM
Default Re: Best Motor? (initial_si)
i meant i would just like to spend 7500 on the entire build, like buy a civic, or watever i find pretty reasonable, but i want the project to be under 10,000, but i want 7500 to be toward the motor
Old Jun 19, 2006 | 07:29 PM
gmadsen100's Avatar
k series or turbo itr
Old Jun 22, 2006 | 04:15 AM
StorminMatt's Avatar
If you are doing your first engine build, then you should build something that is not too costly. After all, you don't want to muck up an expensive motor, do you? Of course, you must find a good balance between cost and expectations of the motor. I feel that a good choice here is a B-series non-VTEC bottom end. These can be picked up for prices that will make the D-series guys eat their own words about B-series being expensive. And the can be built to make BIG power with relatively cheap and common components. They are also quite versatile, allowing you to go VTEC, non-VTEC, or forced induction (in either configuration). Of course, this only really applies if you drive a Civic or Integra.
Old Jun 22, 2006 | 05:20 AM
b18sihatch's Avatar
there is no answer to this other than some motors work well for other peoples builds, its just finding the motor that right suites you... everyone will give you a different answer
TRAG
Mar 9, 2006 12:02 PM
92CivicSIRhb
29
Feb 10, 2006 03:38 PM
civicguy_wi
10
Dec 11, 2003 08:50 AM
Scean
11
Dec 2, 2003 07:08 PM
f@sth@tch89
Sep 18, 2003 09:12 PM
