Best cam gear for D16Z6?
Old Feb 16, 2004 | 02:14 PM
on2wheels's Avatar
Default Best cam gear for D16Z6?
My cam gear timing mark is about half a tooth pitch off when the crank is at TDC. I think this is due to the head being milled, possibly more than once. Anyway, I am trying to figure out what cam gear to get so that I can get the cam timing back to normal.
I did a search and found many complaints about the AEM cam gears because they slip or strip the threads as a result of only having three bolts. However, some people recommended the AEM cam gear because it has the correct "stock" timing mark approximately in the 7 o'clock position for the D16z6. This timing mark lines up with a pointer on the timing belt back cover. Are there any adjustable cam gears with more than 3 bolts and also with the stock 7 o'clock timing mark? If you recommend some other cam gear, what would be the procedure to get the timing back to stock?
Thanks
Old Feb 16, 2004 | 03:31 PM
Doctor CorteZ's Avatar
Default Re: Best cam gear for D16Z6? (on2wheels)
Skunk2 works good , good price as well.
anything with accurate marks and 5 bolts will suffice.
Old Feb 16, 2004 | 05:04 PM
Lord Helmet's Avatar
never had a problem with my AEM cam gear in the 4 years I've been using it. btw a second choice would be the golden eagle cam gear.
Old Feb 21, 2004 | 08:55 AM
on2wheels's Avatar
Default Re: Best cam gear for D16Z6? (sleeperciv)
What would be the timing procedure using the Skunk2 cam gear (or the GE) on the D16Z6? From the information I gathered, the keyway on the '88-95 D-series cams sits at a different angle than on the '96 and up D-series, yet there is only one Skunk2 cam gear model for all of the D-series. Does Skunk2 tell you to use an angular offset for either the older or newer D-series?
Old Feb 21, 2004 | 11:02 AM
D-Man's Avatar
if skunk list one gear for all Ds they need to do thier R+D alittle better
EG-SIXV-TEC
Jun 14, 2013 08:22 PM
sbk23
Jun 19, 2010 04:41 PM
97grnrs
May 10, 2007 03:25 PM
Ignitecivic
Mar 15, 2002 12:32 PM
