bent valve in an lx can i use ITR valves to replace????????????????
Old Jul 2, 2003 | 03:55 PM
redciviclx14's Avatar
Default bent valve in an lx can i use ITR valves to replace????????????????
i just bent a valve the other day on the highway. Damn Misshifts. oh well. i was wondering if i could use the valves from the integra type r or the si valves. also if i coujld use the valve guides from either of the 2. any other advice as to upgrading or just getting refurbished stock valves would be excllent. thank you. tj
Old Jul 2, 2003 | 04:42 PM
Default Re: bent valve in an lx can i use ITR valves to replace???????????????? (redciviclx14)
someone please help im serious about this post! i cant believe no one even has an opinion about this or any suggestions! jeez u guys are supposed to know somethings.
Old Jul 2, 2003 | 06:09 PM
b19coupe's Avatar
Are you asking if DOHC valves will work in a SOHC motor? If that is the question, the answer is no. Buy stock replacement valves from the dealer, and have the entire head checked by a good machine shop.
Old Jul 2, 2003 | 07:11 PM
Turbo Powa's Avatar
Default Re: bent valve in an lx can i use ITR valves to replace???????????????? (b19coupe)
if you need a head I have one with 54,000 miles on it. $150 shipped
Old Jul 2, 2003 | 07:31 PM
Tegeater's Avatar
im not to sure about the ITR valves but I do believe that the SI valves will go.Make sure you did bend a valve and not a rod or a berring i had a prelude where i thought i bent a valve and it turned out to be a Rod.on the other hand if could also just be tapping and in the case you shouldnt even bother with it
VTECcnIT
Nov 9, 2005 05:43 AM
adam94lude
Oct 16, 2005 03:26 PM
2K_TEG
Apr 14, 2002 07:08 PM
98Psi ITR
Oct 29, 2001 03:09 PM
