Benen industries fuel rail...
Old Jan 31, 2009 | 02:29 PM
zippakilla's Avatar
Default Benen industries fuel rail...
ok i need help its the last thing stopping me from starting my build...
the stock fuel line from the fuel filter isnt long enough and runs into where the throttle body is and doesn't match up with the barbed fitting on the fuel rail
basically i'm asking if anyone has had this problem (ive searched the site and came up with thousands of threads and no one in their right mind would look through all of them) so what have you done what did you use... did you send it to a shop to have them redo a stock line or have one made? cost? that sorta thing
thanks guys all help is appreciated
Old Jan 31, 2009 | 03:26 PM
srmofo's Avatar
Default Re: Benen industries fuel rail...
well if you use bulk hose make sure it is for fuel injection, there is a difference in between it and the carb rated stuff.
or you can make a line from SS braided and hose clamps or you could use AN fittings.
its not rocket science, its just a fuel line. It needs to be long enough, be able to handle enough pressure, and be rated for gasoline.
Old Jan 31, 2009 | 03:37 PM
zippakilla's Avatar
yes i know its not rocket science but im trying to do it right... SS braided hose would work? hmm i dont know how to even go about doing it i came on here to ask for help from the "experts"
Old Jan 31, 2009 | 06:51 PM
srmofo's Avatar
here, Ill make this as easy as possible for you , next time please search...contact them before you purchase and give them the length and any other specifics and they'll take care of you
https://honda-tech.com/forums/showth...9966&highlight=
Old Feb 13, 2009 | 04:47 AM
sir2sol's Avatar
i'm actually about to jump into the exact same task as you're doing right now with my benen rail. if you would like, i can give you a 'how to', with part numbers, pictures and everything.
Old Feb 13, 2009 | 04:50 AM
sir2sol's Avatar
btw, that kit isn't going to work for him if he has a benen fuel rail, because that kit doesn't have the adaptor that is needed for the end of the fuel rail. also, the method i'll show him is still cheaper and uses earls fittings and hoses, instead of somthing else.
Old Feb 16, 2009 | 09:37 PM
FarmYard's Avatar
it wont matter if the fuel damper is on the end of the rail???
Old Feb 17, 2009 | 10:26 PM
blinx9900's Avatar
contact user b&R fittings, he can make you a hose with the length/material/fittings you need, prob for around $65-75
fishy21
May 12, 2009 01:06 PM
Kr4nG
Apr 10, 2009 12:48 PM
EK FLY
Jan 6, 2006 05:04 PM
racekar711
Nov 28, 2005 01:18 PM
VspecSiR
Nov 25, 2004 01:48 PM
