fuel lines Q
Old Jan 6, 2006 | 04:48 PM
EK FLY's Avatar
Default fuel lines Q
do u really need a banjo fitting for ur fuel line ?cant it be straight from the filter to the fuel rail deleting the banjo fitting and using a normal an fitting .. would that decrease fuel pressure
Old Jan 6, 2006 | 05:04 PM
stealthmode62's Avatar
Default Re: fuel lines Q (EGSR)
You can run straight AN fittings into the fuel filter and an aftermarket fuel rail. Here is the one that I've made:
I originally had one made with Earl's banjo fittings so that users could use the line on thier stock fuel rail, but it just didn't seal well. The oe honda banjo has a fluid groove in it, and the earls didn't. I axed that model and now the best solution is the straight AN fittings going straight into the fuel rail, but I could find a solution for the stock fuel rail.
BC_Garage
Aug 25, 2012 01:17 PM
EFin' Kyle
Apr 27, 2006 11:43 PM
Mr. Anderson
Feb 21, 2005 08:01 AM
