Before I go mental, please help me identify this noise!
I was almost insane trying to find this noise which coming from under the bonnet or possible from the front right suspension! I have check every possible brushing and linkage and everything! It seems to be fine! But I need your help to identify this, so pleaseeeee, cure my little coupe.
This is a brief summary
•Noise only come when the car is warm (fresh start and quick run?, no noise!!)
•The sound is very similar to the bird signing in HIGH PITCH!! (JIJ, JIG, JIB… JIB) but whispering, not so loud.
•The sounds ONLY come when I push the gas pedal, cruising, or engaging the clutch!
•The sounds Dones’t get louder as I go faster.
•The sounds appear on a bumpy road or even smooth surface, regardlessly.
•Cruising on neutral gear, or not pushing the gas paddle, the sounds GOES AWAY! And come back once I push on the gas to accelerate the car.
•The sounds appear randomly, no rhythm, no pattern BUT ONLY COME WHEN I PUSH THE GAS = Accelerating (JIG JIGGG.. JIG)
My car is JDM Civic EJ7, it is right handed. So the sounds appears just about where my right foot is. The sounds come from exterior of the car and im really not sure if it’s a suspension or something with the transmission?
This is what I have checked so far… my brake, my brushing, my coil over and everything. I’ll take to the shop soon as fast as if I know where is the sound coming from. Could it be clutch bearing?! Or some other things related?! Please advise
Thanks in advance for every answer!
no, I don't have the motor mount inserts
and the radio trick won't work for me
im very suspicious about my drive train, any one?
from what u are saying , it does'nt sound suspension related ,
what i would do , is to take off the
alternator belt ,
air con belt,
power steer,
take belts off one at a time starting with the outer belts one at a time, and go from there ,
alternator belt ,
air con belt,
power steer,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudaChris »</TD></TR><TR><TD CLASS="quote">Have you checked the wheel bearing? It's highly possible.</TD></TR></TABLE>
I'll check its bearing today (but if its the wheel bearing, why does the sound goes away when im cruising? but reappear when i put on some gas to get going? the sound come regardlessly of 5mph or 60mph)
Well, it's not drivetrain related because the sound doesn't get louder, come at
a faster frequency, or change pitch. It only happens when the car accelerates
and goes away at cruise (not under power). Check your throw-out bearing in
your tranny, it could be going out. BTW, is it an automatic, or a standard tranny?
If it's an automatic, then forget my advice, lol.
BnEiAkUiTcY
15
May 30, 2002 09:34 AM
