bearing question?
Old Apr 16, 2002 | 10:56 PM
eddie1681's Avatar
New User
Default bearing question?
Hi
I just bought a JDM B16A bare block for sleeving. My question is I will be transfering my 00' Si crank and rods to this block. Do I need to change the bearings? My motor have only under 35K on it.
Thanks
Old Apr 16, 2002 | 11:09 PM
b19coupe's Avatar
Default Re: bearing question? (b20z)
I would recommend plastiguaging at the very least. If it was me, I would replace all of the bearings (rods and mains).
Old Apr 16, 2002 | 11:13 PM
eddie1681's Avatar
New User
How much are they?
Old Apr 17, 2002 | 12:12 AM
SEFIxCivic's Avatar
yes you would have to change the bearings. match the letters on the block with the numbers on the crank to get the proper main bearings, and match the letters on the crank with the numbers on the rods to get the rod bearings. i highly suggest you pick up a helms before you attempt your rebuild.
the price is approx $170 total (jobber) for all the bearings.
[Modified by SEFI8LOxCivic, 9:12 AM 4/17/2002]
Old Apr 17, 2002 | 02:42 AM
eddie1681's Avatar
New User
Default Re: bearing question? (SEFI8LOxCivic)
Btw is all the B16A block the same, other then the pistons?
tico
Jan 4, 2011 08:43 PM
Wytek9
Jul 27, 2010 05:12 AM
SuckMyDOHC
Jun 15, 2008 11:29 AM
blkb18
Feb 5, 2008 08:07 PM
CBURKE
Jan 9, 2006 06:51 AM
