Battery voltage while running
Old Jul 4, 2016 | 10:25 PM
b16a971's Avatar
Default Battery voltage while running
My batt voltage on hondata s300 is reading 14.xx volts then drops to 12.xx volts and stays there most of the time. Is that normal? When i rev it to 4000 rpm then voltage goes up to 14.xx then drops back down to 12.xx volts as soon as rpm goes down
Its a b16a on a 96 civic chassis
Old Jul 7, 2016 | 04:06 AM
Muckman's Avatar
Moderator in Chief
Default Re: Battery voltage while running
No. It sounds like your alternator is dying. Get it tested.
Old Jul 7, 2016 | 08:40 AM
holmesnmanny's Avatar
Completely normal for a standard dual mode Honda alternator that features a low output and a high output mode.
No parts store has the capacity to test Honda alternators accurately, you have to test it yourself.
Old Jul 7, 2016 | 09:31 AM
redboost10's Avatar
I always cut the "ALTC" wire...even solved the jumping speedo issue
Old Jul 7, 2016 | 11:44 AM
v4lu3s's Avatar
RTFM
sounds normal to me as well. are you having any actual symptoms of a problem?
Old Jul 7, 2016 | 12:39 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yeah sounds about right. When you turn on the headlights or cooling fans,the voltage should jump up, other wise 12.XX volts is about right at idle and no loads.
Old Jul 7, 2016 | 02:46 PM
fcm's Avatar
fcm
Old Fart
Agreed, normal. 94
Old Jul 10, 2016 | 03:22 AM
b16a971's Avatar
Yes it might be the dual output mode.not too many topics online about the dual output mode not even in the repair manual book thats why i want to hear some opinions. Thanks for the confirmation
Old Jul 10, 2016 | 03:36 AM
b16a971's Avatar
I just see the dash lights dimming a little bit when i go on and off throttle but not that bad. I just thought that the voltage changing from 14v to 12v was causing my weak acceleration when im driving my car for around 30 minutes and it loses throttle response and acceleration
Old Jul 10, 2016 | 10:34 AM
fcm's Avatar
fcm
Old Fart
Can't hurt to have the charging system checked out, most batt./alt shops will do that for free, a proper load/gravity check will be done for free a Interstate Batteries for free and takes a few min. 94
meraj
Aug 24, 2011 08:12 AM
Spawne32
Aug 6, 2011 08:21 PM
88 EF Hatch
Sep 17, 2009 07:29 AM
_Endless_
Nov 20, 2002 10:41 PM
ck279
Oct 12, 2001 05:27 PM
