battery
Old Jan 10, 2003 | 11:37 PM
S13 slide's Avatar
Default battery
would the only reason the battery light come on is when the battery is bad? my light comes on when driving but then goes away then comes back on then goes away, any ideas? thanks
Old Jan 10, 2003 | 11:45 PM
Shawn C's Avatar
In The Garage
Default Re: battery (S13 slide)
sounds like the battery is dead, and the only thing keeping you runnin is the alternator. do you have trouble starting??
Old Jan 10, 2003 | 11:46 PM
Shawn C's Avatar
In The Garage
Default Re: battery (22lbGS-R)
1 more question-- does your radio/cd player cut off and on??
Old Jan 11, 2003 | 07:33 AM
Perfectionist's Avatar
The battery light comes on if there isn't enough output from the alternator.
Old Jan 11, 2003 | 12:16 PM
S13 slide's Avatar
Default Re: battery (Perfectionist)
yes the cd player cuts on and off, then the tach went dead. so that would be the battery? thanks
Old Jan 11, 2003 | 12:21 PM
b19coupe's Avatar
What he said. Disconnect the battery with the car running, if it dies, the alternator ain't working.
Old Jan 11, 2003 | 02:03 PM
boostinb18's Avatar
Default Re: battery (b19coupe)
yah do that... and check connections on the alternator.
good luck
Old Jan 11, 2003 | 02:46 PM
S13 slide's Avatar
Default Re: battery (boostinb18)
doh, so the car dies when the battery is unpluged, good thing theres warantee on the alternator. thanks guys
Dj HeetazMalone
Classic Hondas
Jun 15, 2017 07:24 AM
busha61067
Feb 10, 2010 04:54 PM
gascrazy
Sep 17, 2007 06:05 PM
ef9one6
Apr 17, 2007 07:31 PM
dumpedeg6
May 1, 2005 10:24 AM
