bad ignitor?
Old Mar 27, 2004 | 09:54 PM
Origin's Avatar
Default bad ignitor?
hey, ive been trying to find out why i lost spark and i think it is my ignitor (the thing with the spring in it) i always get the coil and the ignitor mixed up. but i was following my chilton, yes i know i should have bought a helms, but oh well anways i was checking the ohm between the + and the - and i was getting a little under .8 which it said was correct. then i tested between the negative screw and the spring and i got 0. this would mean bad ignitor correct? thanks. if that is so, should i go ahead and just replace the coil also or should i just wait and see if the coil turns out to be bad. say if i didn't replace the coil could it damage the ignitor or visa versa. thanks for anyone who can help.
Old Mar 27, 2004 | 10:19 PM
hondatim's Avatar
Default Re: bad ignitor? (Origin)
Actually, what you are testing is the ignition coil. If your Ohmmeter is showing 0 Ohms on the secondary side of the coil, then it is not good. However, I would strongly suggest replacing both the coil and the ignitor together. Generally, if one fails, the other is not too far behind.
Hope this helps
Old Mar 28, 2004 | 10:48 AM
Origin's Avatar
Default Re: bad ignitor? (hondatim)
cool. i just found it very weird because as i was trying to get the car started i had both fuel and spark, but i was having a fuel leaking problem. then when i finally got the fuel leaking problem solved for some reason my ignition coil just crapped out on me.
also, just for future reference let me see if i can get this right. i was testing the ignition coil, so is the little box where the wires hook up at the bottom of the distributor the ignitor? or am i just confusing myself?
Old Mar 28, 2004 | 04:57 PM
nevamind's Avatar
To make it clear for you...ignitor get 4 connectors, the size is about a gameboy cartride; on the other hands, ignition coils is larger, thicker, with only two screw type connectors that marked "+""-", it also have a spring popin' on it. Hope this help clear thing up.
Nerologic
Jan 29, 2007 03:56 PM
96b18c
Dec 28, 2004 11:31 AM
toooslow
Aug 20, 2003 09:12 PM
