Bad idle, Tryed a million things
anything's possible, but I kinda doubt it. Did you try the water trick? Are you getting sucking noises from that area? If so... you might need to replace the IM gasket. it's a bitch to do, but at least it's cheap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 »</TD></TR><TR><TD CLASS="quote">no luck as yet
sucks
im not sure if the injector o rings can cause a leak?'
what ya think</TD></TR></TABLE>
indeed they can! in fact, most do, but some more than others. i have a friend who runs a shop called RT Tuning in PA> he has a smoke machine to find vac leaks. He said he commonly finds these lower injector bushing areas leaking smoke when he checks...
sucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch »</TD></TR><TR><TD CLASS="quote">indeed they can! in fact, most do, but some more than others. i have a friend who runs a shop called RT Tuning in PA> he has a smoke machine to find vac leaks. He said he commonly finds these lower injector bushing areas leaking smoke when he checks...</TD></TR></TABLE>
learn something new every day!
yeah i didn't know either the other day until he told me while talking about how the 1200 dollar smoke machine has paid for itself already through cutting down on search and destroy missions for vacuum leaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 »</TD></TR><TR><TD CLASS="quote">.....one more thing - Are you positive you have the timing on the car dead on?</TD></TR></TABLE>
you are the man!
i love you!
</TD></TR></TABLE>you are the man!
i love you!
I have used my Cam Gears to adjust the position of the exhaust Cam.
I have Advanced the cam gear about 4*.
Should i move it to about 8*?
Startup idle is smooth but low at about. 1100rpm on the Tach
Thanks
Thanks
so can timing cause the this problem too? cause i got the same problem, i did a mini me swap on it and and i dont know if i set my timing right. did a z6 head on a b7 block with z6 adj. cam gear. and dont know if suppose to be advanced or retarded. car runs but sometimes the motor surges.
TheDeadAreBack
Feb 11, 2013 10:56 AM
jdmtegrunner
Oct 18, 2009 11:30 PM
