Bad idle, Tryed a million things
Old Jul 30, 2007 | 10:22 AM
  #26
EnjoyTheRideDC2's Avatar
Default Re: (b16a4)
There's only 2 more things I can think of....
- Throttle body gasket or Intake manifold gasket leak: They must be sealed tight, otherwise they will cause the idle to surge. The fact that you cant even maintain idle with the IACV unplugged is a sign that there seem to be a leak somewhere.
-Timing - You never mentioned what your timing was at. You could be a tooth off in your timing, or you could be incorrectly set.
Get back to us and let us know what happens. Also at this point, throw the IACV lines back on and just leave the coolant lines off of the t-body. This is to maintain a less erratic idle.
Old Jul 30, 2007 | 02:59 PM
  #27
b16a4's Avatar
Default Re: (EnjoyTheRideDC2)
I used carb spray all arround the tb and intake manifold to see if the car will sound different.
Also the car has alot of power so i dont think my timing is off.
Old Jul 30, 2007 | 08:39 PM
  #28
INCNTRL4's Avatar
im having the exact same problem. after a highway pull on my motor.
im doing a leak down test/comp test on weds.
Old Jul 31, 2007 | 08:47 PM
  #29
INCNTRL4's Avatar
Old Aug 1, 2007 | 05:45 AM
  #30
b16a4's Avatar
Default Re: (INCNTRL4)
let me know what you find out!
Old Aug 1, 2007 | 10:25 AM
  #31
b16a4's Avatar
Default Re: (b16a4)
Tryed another ECU and i have the same problem guys.
Old Aug 2, 2007 | 04:23 PM
  #32
b16a4's Avatar
Default Re: (b16a4)
hey guys,
today i measured my TPS voltage and i got .55Volts.
i have a b16a motor. What should my voltage read?
Old Aug 2, 2007 | 04:29 PM
  #33
builthatch's Avatar
MiG-21 superfan
Default Re: (b16a4)
.5 closed throttle, 4.5v at full throttle.
Old Aug 2, 2007 | 04:35 PM
  #34
Turbogixxer's Avatar
Default Re: (b16a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys,
i have a b16a motor. What should my voltage read?</TD></TR></TABLE>
Sounds like that is your problem.
Old Aug 2, 2007 | 04:38 PM
  #35
INCNTRL4's Avatar
Old Aug 2, 2007 | 04:44 PM
  #36
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INCNTRL4 &raquo;</TD></TR><TR><TD CLASS="quote">im having the exact same problem. after a highway pull on my motor.
im doing a leak down test/comp test on weds.</TD></TR></TABLE>
y0 jerkface, you already said the same damn thing 3 times....
still learning the interwebz in canada, EH?
Old Aug 2, 2007 | 04:46 PM
  #37
Default Re: (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch &raquo;</TD></TR><TR><TD CLASS="quote">
still learning the interwebz in canada, EH?</TD></TR></TABLE>
hahahhahaha
Old Aug 2, 2007 | 04:51 PM
  #38
Dengar's Avatar
pittsnogled!
Old Aug 2, 2007 | 04:52 PM
  #39
builthatch's Avatar
MiG-21 superfan
Default Re: (Dengar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar &raquo;</TD></TR><TR><TD CLASS="quote">
pittsnogled!</TD></TR></TABLE>
dude, when the hell did they release you from....hell?!
good to be back, EH?
Old Aug 2, 2007 | 05:12 PM
  #40
b16a4's Avatar
hey
is the .55 going to cause trouble? since its so close to .50?
what ya think
Old Aug 2, 2007 | 05:21 PM
  #41
b16a4's Avatar
Default Re: (b16a4)
got .56 just now
and 4.6WOT
what ya think? bad tps?
do tps just get out of wack just like that?
Old Aug 2, 2007 | 05:44 PM
  #42
builthatch's Avatar
MiG-21 superfan
Default Re: (b16a4)
what ya think</TD></TR></TABLE>
that's fine.
i think its time to do a leakdown.
Old Aug 2, 2007 | 05:55 PM
  #43
Default Re: (b16a4)
I have seen tps voltage off like that cause a bad idle. I would correct it.
But, you said you jumped teeth, I would do a leakdown like builthatch said.
Old Aug 2, 2007 | 06:51 PM
  #44
b16a4's Avatar
Default Re: (Turbogixxer)
thanks
i will try to do a leakdown test
Old Aug 3, 2007 | 10:26 AM
  #45
dizzzane's Avatar
Default Re: (b16a4)
it is possible for a tps to just go bad, it happened to me many times in my 95 civic and would case an erratic idle, surging up to like 1500 and back down to about 600. changed tps and ran fine? sorry if this is no help
Old Aug 3, 2007 | 10:58 AM
  #46
doublethink's Avatar
Default Re: (b16a4)
i had a nasty hunting idle problem that ended up being a faulty coolant temp sensor to the ecu.
it was throwing realy bad info to the ecu.
also, have you fully bled your coolant system, or possibly fully flushed it?
its also not safe to assume timing is perfect just because the car seems powerful. could still be off a bit....
Old Aug 3, 2007 | 05:36 PM
  #47
b16a4's Avatar
Default Re: (doublethink)
how did you find out it was the engine coolant temp?
Old Aug 5, 2007 | 08:49 AM
  #48
INCNTRL4's Avatar
lol, no but apparently when i hit refresh it just reposts it, which is ultra gay
Old Aug 7, 2007 | 03:10 PM
  #49
b16a4's Avatar
Ok guys,
Today i set the TPS to .45V CLOSED!
Still has hunting idle!
Old Aug 7, 2007 | 07:14 PM
  #50
90 Si Hatch's Avatar
Default Re: (b16a4)
I dont mean to jack your post but i'm having the same problem....
JDM D15B vtec, Skunk2 IM & Throttle body...... i just put the motor in 2 weeks ago and the idle goes from 1000k RPM to 1500K RPM. i've unpluged the IACV and the car will idle, but when you give it some throttle it will stutter around 2500K RPM and wont go past. and since then i broke my TPS so i dont think it could be it cause with it not hooked up it just idles HIGH around 2500K RPM, then like a said, whenever you unplug the IACV it will idle around 1000K RPM.....
did a Compression Test, Leak Down Test, Vacuum Test, and it all checks out GREAT. my teacher said in all his years in the automotive field and teaching he said hes never seen an engine check out go good......
any one have any ideas.
Isaac-
