bad idle after cam install
Old Aug 25, 2004 | 06:52 PM
heygotboost's Avatar
Default bad idle after cam install
i'm having problems with the idle after installin a crower stage 1 cam, my idle is so low it causes the engine to stall when in nuetral or 1st or when driving slowly. i have tried advancing the timing and retarding the timing but hasn;t seemed to help .
Old Aug 25, 2004 | 08:31 PM
ferio 95's Avatar
Default Re: bad idle after cam install (94eg9)
which timing cam or ignition?
Old Aug 25, 2004 | 08:55 PM
AutoWerks's Avatar
make sure your cam gears and crank is lined all up at TDC. if you are off a tooth you can have problems. Also Make sure you adust the vavle clearance to the cam specs.
try those. that might help
90LSpimpin
Dec 22, 2004 12:15 AM
heygotboost
Aug 25, 2004 05:10 PM
Tad
Oct 30, 2003 10:23 AM
7rrivera7
Apr 3, 2003 02:00 PM
glock
Oct 12, 2002 08:07 AM
