???? what fuel management is preferred???
Old Aug 25, 2004 | 04:35 PM
maka's Avatar
Default ???? what fuel management is preferred???
i have a b18 and want to run all motor. i do want to tune it and i am considering a vafc, is there a better fuel management out there that i should use? any info thanks..
Old Aug 25, 2004 | 05:35 PM
AdvanTech's Avatar
Default Re: ???? what fuel management is preferred??? (maka)
Well the APEX'i V-AFC is a piggy-back computer, so it is definately not as capable of doing things a stand-alone EMS can do, so to answer your question, most stand-alone EMS are definately better, but if you are not a proffessional racer, and want to use it as a daily-driver, the V-AFc should be more than you need
Also, you should be ale to get cheap V-AFCs as the second-generation has been out for a little while now, but the V-AFC II has a few features not available in the first-generation computer, so it's all up to you.. Good luck with your project
Old Aug 25, 2004 | 06:19 PM
maka's Avatar
Default Re: ???? what fuel management is preferred??? (AdvanTech)
thanks for the info, what is a standalone, what are some names of it>?
Old Aug 25, 2004 | 07:14 PM
PHiZ's Avatar
Use whatever your tuner reccomends.
-PHiZ
Old Aug 25, 2004 | 09:01 PM
AutoWerks's Avatar
if you dont have any major work on the motor. then the AFC is fine. if you due. upgrade to a hondata... works great
dand39
Jan 29, 2005 08:55 AM
1999all_motoR_teg
13
Jan 12, 2005 09:53 AM
bpowa
10
Oct 26, 2004 11:09 PM
b18b98
Dec 12, 2002 05:23 PM
EK9Blitz
Oct 3, 2002 10:52 PM
