bad IACV or TPS
Old May 19, 2006 | 08:28 PM
White_EK49's Avatar
Default bad IACV or TPS
Situation: I have a b16 turboed EK with AEM. During normal start up is fine. After a long drive on the freeway, the car start to surge 2000 rpm to 3500 rpm. I stopped the car and unplug the IACV plug and the car idle at 2000 steadily. I drive the car home and put on a new but used IACV and the car started up fine with no surges. After that, I take th car for a drive again. The same thing continues WTF. I check my TPS voltage and it's fine. I checked the Vacuum and it's also within spec. My car does not have the FITV. It's a BDL 70mm throttle body. This just drives me crazy. I have replaced the thermostat and radiator cap too. Bled all air out of the system. Have any suggestion? Can timing put it out of sequence?
Old May 20, 2006 | 09:21 AM
longuyen88's Avatar
the surges is bad when it's warm right? i have the same problem bu on a na b16
Old May 20, 2006 | 10:34 AM
White_EK49's Avatar
Default Re: (longuyen88)
Yes, it surges when it is warm. Usually after 20 minutes of driving. When the motor cools down. It is okay.
k2day
Nov 19, 2011 09:38 PM
vortech_s2000
Nov 27, 2006 04:21 AM
Kyles ej1
10
Jun 11, 2006 02:36 PM
99PreludeSh
Jun 9, 2006 07:36 AM
SeaBass
Jul 3, 2003 07:46 AM
