bad head gasket on d16a6-what should i replace it with?
Old Oct 14, 2005 | 06:47 PM
hb_guy's Avatar
Default bad head gasket on d16a6-what should i replace it with?
i just picked up a 1990 civic ex sedan for 100 dollars in GREAT shape from an older lady, had new tires and a month old exhaust that she showed me reciepts for(plus you can tell they are new). car has high mileage but it started and ran fine for 30 seconds to move out of her driveway to the tow truck-no issues.
i want to just replace the head gasket for now until the spring when i am going to swap in my old motor. i was thinking of using the d16y8 two layer head gasket instead of the a6 head gasket. what do you guys think? suggestions?
thanks
Old Oct 14, 2005 | 08:23 PM
hb_guy's Avatar
Default Re: bad head gasket on d16a6-what should i replace it with? (hb_guy)
anyone?
Old Oct 15, 2005 | 02:22 AM
91civicDXdude's Avatar
get an autozone/advanced/oreillys/pepboys, etc. gasket for a 92-95 civic EX /Si. its the same metal gasket as the y8 uses and alot cheaper as its not from the dealer
Old Oct 15, 2005 | 07:20 PM
A1's Avatar
A1
Default Re: (91civicDXdude)
either z6 gasket or the y8.they are both metal gasket .
Old Oct 16, 2005 | 06:17 AM
d16dcoe45's Avatar
Default Re: (d16why8)
If the car is running fine now, and you are doing a swap in the near future, why do you even want to replace the headgasket? If its the original d16a6 hg, its going to be a graphite/composite gasket that after time sticks to both the head and block--and when you try to pull them apart the gasket rips and leaves a big mess. I would just leave it. Don't fix what isn't broken.
Old Oct 16, 2005 | 03:18 PM
hb_guy's Avatar
Default Re: (d16dcoe45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">If the car is running fine now, and you are doing a swap in the near future, why do you even want to replace the headgasket? If its the original d16a6 hg, its going to be a graphite/composite gasket that after time sticks to both the head and block--and when you try to pull them apart the gasket rips and leaves a big mess. I would just leave it. Don't fix what isn't broken.</TD></TR></TABLE>
it needs a head gasket, that's why, i need a good running car. swap comes later when i have it complete
DelSol-B-18
Apr 8, 2005 06:46 AM
drewlee
Aug 9, 2004 12:00 PM
AgentJam
Dec 18, 2003 08:34 AM
S13 slide
Jan 4, 2002 06:20 PM
therealnapster
Sep 10, 2001 01:32 PM
