bad fuel injectors?
Old Oct 1, 2006 | 09:59 AM
0h0hdc2's Avatar
Default bad fuel injectors?
Two months ago I overrev my car and bend most of my valves and throwing code 16. Now recently i have all 16 of my valves replace and putted everything back with new gaskets. When i started the car it idles funny, like the rpm moves up and down then sometime it just stay at 1k rpm then when i give it a little gas the rpms starts doing the same thing then sometime it stay at 200 rpm. havn't drove it since i got everything replace b/c its not running right. check the timing and everything seems to be at tdc and I could smell unburn fuel and no cel. Did compression test, 230 on all 4 cly compare to b4 196,10,10,10. btw the car is 00 gsr , everything is stock with 42k miles and everything was replace with oem honda parts.
Old Oct 1, 2006 | 12:06 PM
qfast817's Avatar
Default Re: bad fuel injectors? (0h0hdc2)
check timming, also look for vac leaks
lamesa
Jan 2, 2015 04:06 AM
OH_1fstgsr
May 6, 2014 08:50 AM
manicmechanic
Honda Civic (2001 - 2005)
Apr 28, 2014 08:19 PM
ShagginJet
14
Sep 6, 2006 02:18 PM
Nextelbuddy
Apr 5, 2004 07:14 AM
