Code 16 will not clear anymore
Old Dec 4, 2013 | 04:55 PM
OH_1fstgsr's Avatar
Default Code 16 will not clear anymore
I now have code 16 on my 1999 GSR with a Hondata S300 in a P72 ECU with IAB. Code 16 is injectors NG. All 4 have the correct resistance. Checked the wiring harness. All OK.
Changed Spark plug wires, they are 12 years old. Thought one might be bad and arching out.
Now the back story. This didn't happen all at once. It came on gradually. The car went from 100% ok to now in about two weeks time. Each day it would get worse and worse but would clear up when I hit the gas. Now the car idles like a Subaru.
No other codes or problems.
I'm looking for any more ideas.
Anyone else have trouble like this?
Old Dec 4, 2013 | 05:51 PM
MyEgHatch's Avatar
Default Re: Code 16 will not clear anymore
Do you have an extra set of injectors to test and see if one failed?
Old Dec 4, 2013 | 06:16 PM
B_Swapped93's Avatar
any mods done to the engine ? stock injectors/stock fuel pressure.
Old Dec 4, 2013 | 09:08 PM
mouab18c1's Avatar
Sounds like a subaru? Car isn't getting fuel. Make sure all your injectors are opening. If you have another ecu I would try that as well. Injector drivers might have taken a **** in the ecu.
Old Dec 4, 2013 | 09:35 PM
Eg.ls.turbo's Avatar
Brother's car did the same check ur fuel pressure. We had a bad fuel pump.
Old Dec 4, 2013 | 09:53 PM
10psiLsEf2's Avatar
Identify which cylinder is dead by pulling the spark plug wires one at a time. The engine should stumble while doing this. When you get to the cylinder that doesnt make the engine stumble. THATS YOUR MISFIRING cylinder. Or if afraid of being shocked, pull injector clips instead.
So lets say cylinder #4 is dead. Swap injector # 4 and put it in #1. And put #4 in cylinder 1.
Start it and see if #4 is still misfiring.
Old Dec 5, 2013 | 03:35 AM
OH_1fstgsr's Avatar
No extras. Running ID725’s, only two years old. Checked out ok . 11.9~12.1 ohms.
Engine is moderately modified, PnP Head, ITR Cams, Custom GSR Dual Runner Intake Manifold, Block ITR Pistons. Stock Fuel Pump and Stock Fuel pressure.
Mouab, long time. Thanks.
My tuner said his fuel pump died at 100,000 miles in his GSR. I’m at 140,000 miles and 14 years old. Thinking it might be time for new fuel pump. The ECU is a P72 with an S300. My tuner should be able to help me here if I need to do a swap.
All the injectors and wiring ohm’d out ok. The spark plugs all look exactly the same. Which now leads me to believe fuel system more strongly. Time for a new full pump.
Everyone thanks so far. Any more insight would be greatly appreciated.
Old May 4, 2014 | 04:42 PM
OH_1fstgsr's Avatar
Full Pump changed. Still having the trouble. Crap.
Starting to think it might be the main relay. This problem came on over time not all at once. Changed the main relay in my Del Sol many many years ago. Can't remember the exact troubles.
Anyone have advice?
Old May 6, 2014 | 08:50 AM
tamboo's Avatar
10 Year Member
http://techauto.awardspace.com/mainrelay.html
93LsVx
Aug 28, 2010 09:20 AM
SkIp_Civic_Ek6
Jan 17, 2007 07:37 PM
H22A EG6
Mar 31, 2005 07:53 PM
delux247
Jan 28, 2004 11:48 AM
turboxsi
Sep 17, 2003 06:00 PM
