b2o vtec no problems
Old Nov 9, 2003 | 12:44 PM
NastyVtec's Avatar
Default b2o vtec no problems
i have had my daily driven b20 vtec for 22,000 daily driven miles and i heard alot of people having problems wih the bottom end. I have an 85mm over bore and arias 12:5:1 compression and thats it on the bottom end, the only strange thing it does is when the motor is running and i open the dipstick i hear compressed air coming out of the block, and it burns a little tiny bit of oil but doesnt leak a drop of anything...
Old Nov 9, 2003 | 03:11 PM
non-VTEC's Avatar
Default Re: b2o vtec no problems (dynastix9)
85mm on stock sleeve B20 block?
Old Nov 9, 2003 | 06:12 PM
NastyVtec's Avatar
Default Re: b2o vtec no problems (non-VTEC)
yep with 12:5:1 compressdion on stock block no sleeves or block guard had no problems except minor oil consumption and that pressure release noise coming from the block when i take out the dipstick when the oil is running.
Old Nov 9, 2003 | 06:23 PM
DVS_EF's Avatar
except minor oil consumption and that pressure release noise coming from the block when i take out the dipstick when the oil is running.[/QUOTE]..... :
Old Nov 9, 2003 | 11:38 PM
tinkerbell's Avatar
Default Re: b2o vtec no problems (dvsEF)
what PCV system are you using?
what engine management are you using?
Old Nov 10, 2003 | 02:46 AM
91tegrals's Avatar
isnt a b20 stoke bore 84mm
Old Nov 10, 2003 | 05:49 PM
NastyVtec's Avatar
Default Re: (91tegrals)
yes
Old Nov 10, 2003 | 08:03 PM
Patch's Avatar
Default Re: (dynastix9)
What cams? How much oil consumption?
Old Nov 10, 2003 | 08:40 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynastix9 &raquo;</TD></TR><TR><TD CLASS="quote"> only strange thing it does is when the motor is running and i open the dipstick i hear compressed air coming out of the block, and it burns a little tiny bit of oil but doesnt leak a drop of anything...</TD></TR></TABLE>
u probbaly need a better pcv system
Old Nov 11, 2003 | 07:25 AM
NastyVtec's Avatar
Default Re: b2o vtec no problems (Sp00n'd Supra)
2000 jdm integra type R cams and it burns no oil if i dont run the car but if i run it it burns a little bit but no leaks and what do you recommend on the pvc system????
Old Nov 11, 2003 | 08:15 AM
skribblah's Avatar
the endyn breather system:
http://theoldone.com/components/breather/
Old Nov 11, 2003 | 03:20 PM
NastyVtec's Avatar
Default Re: b2o vtec no problems (skribblah)
you think this will help and will it install with my oil catch can and how much is it?
Old Nov 11, 2003 | 03:21 PM
Patch's Avatar
"The kit comes complete with the Moroso breather tank, Moroso breather element, (2) block vent tubes with aluminum gaskets, PCV valve and neoprene grommet, and all hoses and clamps for installation for a price of $154.00."
D'oh
Old Nov 11, 2003 | 03:29 PM
NastyVtec's Avatar
Default Re: b2o vtec no problems (Patch)
do you think this will eliminate the excess crank pressure and possiblwe a little of my ring blowby?
Old Nov 11, 2003 | 10:32 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynastix9 &raquo;</TD></TR><TR><TD CLASS="quote">do you think this will eliminate the excess crank pressure and possiblwe a little of my ring blowby? </TD></TR></TABLE>
yup, AND u make more power and less chance of detonation
google55
Jan 31, 2013 04:48 AM
RED_90TEG
Mar 21, 2007 06:24 PM
carboy_honda
15
Jan 16, 2006 06:27 PM
knoj
Nov 15, 2005 04:28 PM
ace1875
Jun 13, 2003 11:49 PM
