B20B Flywheel bolts
Old May 24, 2006 | 07:56 PM
dpaton's Avatar
Default How to fix a B20 crank?
I'm working on a JDM B20 I'm rebuilding for my brother, which came as a long block sans flywheel. In trying to remove the crank pulley, I figured I'd just bolt a bar to the other end of the crank and work on the bolt with a breaker bar like I usually do. Only one problem....the flywheel bolts for a B20 (12x1mm 12pt, HOP# 90011-PH3-000, same for all B series motors) don't fit. Turns out someone boned the crank before I got it. Of the 8 holes, I can get a bolt to thread cleanly into ONE of them. The rest...it's bad.
I figure I have 2 options...replace the crank ($$$) or try and run a cleaning tap through the holes and pray that there is enough thread down in the crank to provide the holding torque required.
Thoughts?
Pictures in the next post.
-dave
Modified by dpaton at 11:42 PM 5/24/2006
Modified by dpaton at 11:43 PM 5/24/2006
Old May 24, 2006 | 09:45 PM
dpaton's Avatar
Default Re: B20B Flywheel bolts (dpaton)
Wide shot of the flywheel end of my crank. Pay no attention to the fluid in the holes...it's just WD-40 I used to clean some of the grime off. Macro of one of the bolt holes.
Click to biggify.
It's worse on a few others, but the pictures didn't come out.
Old May 25, 2006 | 06:28 AM
franktype-r's Avatar
Default Re: How to fix a B20 crank? (dpaton)
Run a rethreader through it. It should be fine. Ive done this many times.
Old May 25, 2006 | 07:24 AM
dpaton's Avatar
Default Re: How to fix a B20 crank? (franktype-r)
I'm hoping so. Now, to find a 12x1mm cleaning tap in this joke of a suburb....
Thanks
-dave
eh2_Trav
Transmission & Drivetrain
Nov 4, 2016 08:47 AM
jasonfierst
Oct 18, 2009 01:04 PM
earl
Oct 8, 2006 06:53 AM
Ignitecivic
Mar 20, 2004 09:41 AM
ryu12341
Jun 23, 2002 05:39 PM
