B20 vtec problems
Old Jan 14, 2009 | 01:45 AM
wishingiam's Avatar
Default B20 vtec problems
94 del sol
95 gsr ecu
b20z block
00 gsr head
itr cams and valvetrain
Car was running great for a few years, but now that I don't drive it everyday when I go to drive it, it's a chore. I try to take it out on the weekends.
When I start the car it 's missing on one cylinder, or dies out. Idk which one since nobody is around to help me. But after a few tries I can get it to idle kinda, it sounds like a wrx. After holding it at idle for about a minute while it's still missing it'll clear up and idle normal.
I've checked the fuel pressure, it's around 50, there are NO cel. And it will drive normal after it warms up.
Things I've tried
Fuel filter
Fuel pump
Plugs, and wires
Injectors were sent out and cleaned
Gas cap, I get the vacuum sound everytime I open it.
I really like the car, but knowing I can't just hop in and drive is making me irratated.
Could it be just the gas? I always run 92, but other people I asked said maybe the gas cap is letting in enough moisture and it could be possible that's what causing my problem.
Old Jan 14, 2009 | 03:27 PM
str8boost's Avatar
Default Re: B20 vtec problems
try a known good distributer... could be ur coil getting weak...
Old Jan 16, 2009 | 06:46 AM
kevinz's Avatar
Does it still miss when you drive it?
Old Jan 16, 2009 | 08:53 AM
Evs-One's Avatar
Solbros Owns Me
I just had a cust who had some hacks put a GSR head on his B20 bottom end....same thing you are describing...ended up being a leaky head gasket, although it wasn;'t overheating.
Old Jan 16, 2009 | 10:42 PM
wishingiam's Avatar
Tried another distributor, still misses when cold.
Drives perfect, if I have the patience to get it warmed up.
I did the conversion myself about 5yrs ago, really hope it's not the headgasket. It does not blow any smoke at all, and is'nt going through any oil that I can tell.
Austin Britton
Sep 4, 2017 06:24 AM
Shanasman12
Apr 9, 2014 08:45 PM
that_boy_sammy
Nov 18, 2013 02:15 PM
b20vteg757
Jul 28, 2013 02:17 PM
KYDelSol
Aug 6, 2012 10:36 AM
