B20 Vtec dies when rpms drop
Old Jun 11, 2013 | 05:48 PM
joiv21's Avatar
Default B20 Vtec dies when rpms drop
I have a stock b20 vtec.
The problem only seems to occur when it warms completely up. I give it gas it sounds like its getting alot of more air then the fuel kicks in and it revs so it kinda whistles then revs. but when i let off the throttle the rpms fall and dont catch and the motor dies.
I have a oil catch can setup one hose to the back of the block one hose connected to pcv and bottom drain hole block with vent on top.
Has chipped ecu with b20v basemap.
Already tried b20vtec.com but chrome isnt liking that website
Old Jun 11, 2013 | 09:29 PM
joiv21's Avatar
Default Re: B20 Vtec dies when rpms drop
come on guys don't be shy.
Old Jun 11, 2013 | 10:28 PM
Uncle Dave's Avatar
Maybe the base map is not for your B20
Old Jun 12, 2013 | 10:58 AM
darksands's Avatar
Oh the irony of using the word stock when talking about B20Vtec... I am going to say that your tune is no bueno at idle.
Read Idle problems and oscillation section: http://www.hondata.com/techidle.html
Old Jun 12, 2013 | 01:00 PM
joiv21's Avatar
Is this the only answer im gonna get from honda tech is the tune? Alright ill take your word for it. Im gonna take it down here to mainstream performance and let them dyno it.
ps You so called techs? SUCK!
Old Jun 13, 2013 | 11:01 PM
darksands's Avatar
So if it is the tune, do we still suck?
Old Jun 14, 2013 | 05:14 AM
HondaPartsHero's Avatar
Technical Hero
Why don't you just try a stock ECU first if you have access to one. And always when you make a thread list as much info as possible, ie year, make, model, mods, ECU, recent or any known maintenance done, CEL on with codes, etc. just saying your b20v dies at idle doesn't help without that extra info to go on.
Old Jun 14, 2013 | 05:19 AM
JuggerNaut-CTR's Avatar
I have a buddy you was going thru this same exact problem just the other day. It has since been resolved with my help. Too bad you're not gonna hear my awnser, since I suck and all
Old Jun 17, 2013 | 05:24 AM
joiv21's Avatar
I tried my p2t Ecu and it still wanted to choke rev up then die when I pressed the gas. Sorry about the post earlier guys I was just very frustrated with my phone and I took it out on you guys.
Old Jun 17, 2013 | 05:38 AM
joiv21's Avatar
No check engine light 2000 civic Si with STOCK internals
hollywood97civic
Aug 30, 2011 08:11 PM
immrtaltchnq
Oct 21, 2008 07:46 AM
cyrix12
Aug 25, 2005 06:59 AM
KilaB18C
Oct 15, 2004 09:08 AM
Kamin
Jun 4, 2002 12:44 PM
