B20 **help*
Old Jan 29, 2009 | 10:10 AM
89vwfox's Avatar
Default B20 **help*
i have an 90 obd1 b20 civic si
PROBLEMS: Wont start, the relay wont click, check engine light,keep blowing my 15a ECU fuse, and no fuel pump
i just replaced the main relay with Part # R3264 at oriellys on my receipt it says its for a 1.5 civic not the si. not sure if it matters but i put the new relay in and it didn't do a thing still no fuel pump. and every time i turn the key to the ON position i blow my 15a ecu fuse.
WHAT THE HECK COULD THIS BE???? what i thought would be a simple fix is turning into a big headache
Old Jan 29, 2009 | 10:16 AM
mouab18c1's Avatar
Default Re: B20 **help*
check for a ground wire shortage...and what you mean no fuel pump? not priming?
Old Jan 29, 2009 | 10:18 AM
89vwfox's Avatar
yea its not priming
Old Jan 29, 2009 | 10:40 AM
89vwfox's Avatar
checked my ground it was good
Old Jan 29, 2009 | 11:00 AM
89vwfox's Avatar
my battery is pretty much dead after doing so many tests............. so i can hear my fuel pump turning on when i try to cranking it.
Old Jan 29, 2009 | 11:24 AM
89vwfox's Avatar
Its gotta be my fuel pump right? its obviously getting power but its not priming. But why do i keep blowing my ecu fuse?
Old Jan 29, 2009 | 11:43 AM
fcm's Avatar
fcm
Old Fart
Unplug the PGM-FI Main Relay, [fuel pump relay] and turn ign. on and see if ECU fuse still blows, if not then either the fuel pump, fuel injectors or one of the engine sensors powered by the PGM-FI Main Relay or the wiring to the above has a short, if fuse still blows my guess is the ECU is shorted out. 94
Old Jan 31, 2009 | 10:49 AM
89vwfox's Avatar
just put the new fuel pump in and im still blowing my 15a fuse.....
Old Feb 2, 2009 | 12:22 PM
mpls's Avatar
your ecu is fcuked get a new ecu
Old Feb 2, 2009 | 03:49 PM
mouab18c1's Avatar
well your fuel pump wont prime if your ecu is not working...simply just swap it out and try on another one...to see if it works...
Old Feb 3, 2009 | 11:35 AM
89vwfox's Avatar
i tried unplugging my o2 sensor and it fired right up wtf
Old Feb 4, 2009 | 07:04 AM
mouab18c1's Avatar
try replacing it with a new o2 sensor then
Old Feb 4, 2009 | 08:10 AM
patriot's Avatar
One time, a buddy(i use the term loosely) of mine welded an o2 bung into his header. The location waas very bad. Once it was bolted up it smashed the o2 sensor into the subframe. HAHAHAHA...yeah definately fried a couple wires, lol.
dgdarien
Jul 20, 2017 02:37 AM
pedroa06
Jun 30, 2013 06:43 PM
gsr_sleeper916
Mar 27, 2011 06:59 AM
89vwfox
Jan 31, 2009 11:54 AM
frost_0ne
Sep 13, 2005 01:02 PM
