b18c1 wont crank
Old Apr 5, 2016 | 01:42 PM
jerryluvkiki's Avatar
Default b18c1 wont crank
I have a 92 Honda civic hb. I have a obd2 b18c1 motor. The motor wont start or turn. The light and everything turns on but no turn on starter. I test the starter but autozone said it good. I try the stater, distributor, main relay, ECU, ground, checked the fuse. It everything I can think of. I need to get it fix as soon as possible.
Old Apr 5, 2016 | 02:03 PM
Default Re: b18c1 wont crank
The car wont start. when i tried to jump start it i wont start. but if i kick start like push the car and then push it into gear. it will crank but when i turn it off it wont staRT AGIAN....HELP
Old Apr 5, 2016 | 06:48 PM
2kdrift's Avatar
sounds like your starer may not be wired correctly...try manually feeding voltage to the solenoid?
Old Apr 5, 2016 | 11:10 PM
Joey Lor's Avatar
you need a new starter. even if they say its good. been in this situation before. try testing a different starter. hope this helps
Old Apr 6, 2016 | 02:03 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Possible bad ignition switch.
Or bad started or incorrect wiring. Confirm starter wiring and try to manually power the starter.
Old Apr 6, 2016 | 01:07 PM
Ok ill get a new starter and see what happen.. Thanks
Old Apr 6, 2016 | 01:15 PM
fcm's Avatar
fcm
Old Fart
I have a simple DIY starter circuit test in the sickies at top of this form try that before you toss any more parts at your problem. 94
Jeannies car
Sep 6, 2015 09:26 AM
JorgeR559
Jun 10, 2014 10:50 AM
loayo
11
Mar 12, 2012 12:49 PM
jimboek
Apr 26, 2007 07:12 PM
hmonglonertim
Apr 26, 2002 02:12 PM
