b18c1 sensor help
Old Nov 18, 2013 | 05:06 PM
nogodracer23's Avatar
Default b18c1 sensor help
ok some of you guys are gonna read and say what the hell, but i need some help figuring out a sensor, if youre looking at the motor, you have the vtec solenoid and under that you have the coolant temp sensor, and theres one kinda next to it and below it and i looked online and threw the haynes manual and i cant find out what it is. so i know theres some guru's on here that can help me.
Old Nov 19, 2013 | 05:38 AM
kyden's Avatar
Default Re: b18c1 sensor help
picture? on the head there should be the coolant temp sensor and the sender for temp gauge in your cluster.
Old Nov 19, 2013 | 11:48 AM
HondaPartsHero's Avatar
Technical Hero
Old Nov 19, 2013 | 11:51 AM
Colin's Avatar
^ Terminology in that diagram doesn't really match the Helms. So just to clear things up:
ECT Switch = Fan switch
ECT Sensor = TW Sensor
ECT Sending Unit = Coolant Temperature
Old Nov 19, 2013 | 11:56 AM
UGAVtech's Avatar
Originally Posted by HondaPartsHero
Good reference!
Old Nov 19, 2013 | 02:39 PM
Technical Hero
Fan switch = cooling fan switch
Coolant temperature = sends signal to gauge cluster
TW sensor = sends signal to ECU
Old Nov 19, 2013 | 03:11 PM
HondaPartsHero youre the **** thats exactly what i needed
Old Nov 20, 2013 | 12:10 PM
Technical Hero
Here's another in case you need it
jlowellintegra
Jun 10, 2011 10:18 AM
kramer06
Jan 24, 2008 05:41 PM
Simmerman
12
Sep 18, 2007 07:05 PM
whiterex
Feb 28, 2005 02:57 PM
