B18c internals in 18a block?
Old Oct 11, 2006 | 06:43 PM
  #26
dmotoguy's Avatar
Default Re: B18c internals in 18a block? (beef-cake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beef-cake &raquo;</TD></TR><TR><TD CLASS="quote">LOL, I said that b18a/b are different than b18c, YES, that's what I said.
you did say that, and you are still wrong, they are the same deck height.
Old Oct 11, 2006 | 06:49 PM
  #27
beef-cake's Avatar
Default Re: B18c internals in 18a block? (dmoto)
Where is your proof? Somebody has to have a honda shop manual that shows the blocks specs, but i'm guessing you don't have one. That's what i've been asking for all along.
Old Oct 11, 2006 | 06:56 PM
  #28
dmotoguy's Avatar
i have some in my shop... im at work.. there is the problem.
do some quality research online.. quite easy to do (i'm not talking about searching on some forums)
or save some time and believe us, thats why we are here.
B18a/b/c deck heights are all the same
here is a link to back up what I am telling you, look at the chart :
http://www.raceseek.com/honda_specs.htm
Old Oct 11, 2006 | 08:03 PM
  #29
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beef-cake &raquo;</TD></TR><TR><TD CLASS="quote">Where is your proof? Somebody has to have a honda shop manual that shows the blocks specs, but i'm guessing you don't have one. That's what i've been asking for all along.</TD></TR></TABLE>
honda helms manual does not state deck height, compression height nor rod lenght buddy.....
And yes I've seen b series motors apart. b16 with ctr internals on spray, b20 with ctr internals and big cams. About to take my gsr and LS apart to combine them. And I have a b16 in my hatch.
Yeah so you saw a b16 block with what part of CTR internals?
And what a b20 with ctr crank and rods?
because im assuming that you already know that b20 pistons are 84 mm right?
Soo what pistons what he using??
Old Oct 11, 2006 | 10:05 PM
  #30
98vtec's Avatar
moderator emeritus
i know its not a bseries...but check this out
Deck Height
H22A4 Block = 8.643
H22A block = 8.643
H23A block = 8.643
H23A1 block = 8.643
F22 block = 8.643
F23 block = 8.643
F20B block = 8.643
Old Oct 14, 2006 | 08:35 PM
  #31
beef-cake's Avatar
Default Re: B18c internals in 18a block? (mmuller)
Muller, that's why I've been asking for 5 days if somebody has the figures from a honda manual, because I don't have one, and figured it would be in there, but FINALLY you inform me that they aren't there.
This is what Earl said:
earl (10:38 AM 10/12/2006): 212mm is pretty much the generally accepted block height of the b18X blocks (also the K20) so I'm not sure where they get their numbers. I believe the numbers used on that site are submitted by users but maybe they are right, I can't say for sure. In any case you really need to measure your own personal block and then do the calculations.
SO since 4-5 of you say its the same, Earl says its the same and the Honda manual doesn't have info about it, i'll stop searching about it and assume they're the same. (To assume makes an *** out of you and me however)
Old Oct 16, 2006 | 06:19 PM
  #32
dmotoguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beef-cake &raquo;</TD></TR><TR><TD CLASS="quote"> (To assume makes an *** out of you and me however)</TD></TR></TABLE>
Mostly you jp
Old Oct 16, 2006 | 06:42 PM
  #33
beef-cake's Avatar
true
xkjnboix
Mar 14, 2016 06:16 AM
nolicense526
May 30, 2009 12:10 AM
Wytek9
Apr 23, 2008 09:32 AM
Corinthians
Oct 8, 2004 10:39 AM
00 FBP ItR
Mar 19, 2003 01:26 PM
