B18C: Differences between JDM and USDM crankshafts??
Old Mar 30, 2003 | 05:24 PM
saber1's Avatar
Default B18C: Differences between JDM and USDM crankshafts??
I have a JDM B18C and while I was attempting to put the new clutch and flywheel on I noticed that the pilot bearing that came with the Exedy clutch kit wouldn't fit in the opening on the end of the crankshaft. However, Carquest handed me the same bearing when I asked for one about an hour later. So I started thinking, is the JDM crankshaft different than the USDM version? From the end of the JDM one, it appears it takes a bushing and NOT a bearing for the input shaft. Can anyone confirm this? If this is the case, where can I get the correct busing?
Old Mar 31, 2003 | 05:48 PM
saber1's Avatar
Default Re: B18C: Differences between JDM and USDM crankshafts?? (saber1)
Anyone?
Old Mar 31, 2003 | 05:53 PM
Kataku2K3's Avatar
NEVER had this problem before.... You sure they gave you the correct flywheel/pilot bearing?? Good Luck
Old Apr 1, 2003 | 09:55 AM
saber1's Avatar
Default Re: B18C: Differences between JDM and USDM crankshafts?? (Kataku2K3)
I think I got figured out.
Records
Feb 27, 2012 03:19 PM
antaren
Nov 6, 2007 05:44 PM
mcc361
Sep 4, 2007 05:27 AM
Hilary_duff
Feb 23, 2005 08:43 AM
hybrider
Apr 21, 2002 04:02 PM
