b18a1 missing/backfiring
Old Dec 31, 2013 | 01:26 PM
onemanwolfpack's Avatar
Default b18a1 missing/backfiring
I couldnt get my car to start after it sitting for awhile. Then finaly I sprayed some starting fluid in it and it stated but ran rough. Then I shut it down after running for a few minutes and it started back up without starting fluid.
Today, went to start it again and it would not until I used startig fluid. I checked the plugs and all were alittle black but #4 was black and wet with fuel. If I try driving the car, it pops, misses, backfires, jerks ect... above 2500rpms. Seems like it gets worse when it warms up to normal operating temperature. After I parked it, and kept it running, if you reved it, it will miss.
Its a b18a1 in a 91 civic si. The ecu is a obd1 p75 ecu, obd1 distributor but I am still running obd0 injectors resistor box. It has a egr thing still on the intake manifold which is not plugged in.
Old Dec 31, 2013 | 05:28 PM
Default Re: b18a1 missing/backfiring
Ive done cap, rotor, coil, plugs, plug wires and its has no change. The engine light is on but, when I try to jump it get find out the codes, nothing happens. As soon as I start it, the light comes on. Shut it off, jump the wires, turn the car on, no engine light or flashing.
Old Dec 31, 2013 | 06:24 PM
hybridmiklo's Avatar
obd 0 injectors are different than obd1. but if you are using starter fluid to start the car than you are looking at a fuel issue. put a gauge on it and see if you are getting enough fuel pressure. Also try another obd1 ecu to see if you can pull codes.
Old Dec 31, 2013 | 06:46 PM
I was thinking it was a fuel issue. Yea, I know ond0 are different but I still have the resistor box in it and as far as I know, they will work. I cant find another ls ecu local right now, ive already tryed looking. the plugs being completely black tells me too much fuel... could be wrong on that though. Ill get a fuel pressure guage tomorrow and check that.
b18ef
Apr 17, 2009 08:05 AM
Lucky-13
11
Mar 23, 2007 11:56 AM
Benbuilt4u
12
Dec 25, 2005 09:11 PM
camboMONK
14
Dec 8, 2005 08:11 AM
