B18 OEM 3-belt crank pulley question
Forgive the newbie question, but I did not find an answer with some searching on Google.
My B18 motor swap project nearly completed (into classic Mini). The alternator is custom-mounted. The motor still has the OEM Honda 3-belt crank pulley. Alternator is currently running off the center pulley. I'm considering running an ATI super damper, race only alternator pulley... but I just realized I'm not sure which of the three pulley positions the alternator is supposed to run from, and if an aftermarket, alternator-only pulley would be correctly spaced.
Would someone please explain which oem pulley (inner, center, outer) runs which accesrory?
Thank you.
Thank you.
Hockey27925
06-16-2005 04:18 PM
