b17
Old Feb 13, 2003 | 07:25 PM
Seye's Avatar
Default b17
What does everyone think about the b17, i have heard good and bad stuff.
Old Feb 13, 2003 | 07:56 PM
StorminMatt's Avatar
Default Re: b17 (sixsk8)
Since it is a DOHC VTEC, it can't be that bad. In fact, it is not bad at all. Actually, this motor is fairly similar to the B16A. It uses the same head assembly and block. Only the crank, rods, and (probably) pistons are different. Simply put, it is a B16A that has been stroked to 1.7 liters. Its compression ratio is also slightly lower. Power output is the same 160HP as the B16A. But naturally, you get more torque due to the larger displacement (117ft-lb vs 111ft-lb). The rod ratio is not as good as the B16A (about 1.62:1 vs 1.74:1). But 1.62:1 is still pretty good for a Honda motor. If you get the motor with the transmission, you get a very nice transmission - the YS1. But the main problem with this motor is its rareness and cost.
Old Feb 13, 2003 | 08:01 PM
Seye's Avatar
Default Re: b17 (StorminMatt)
well i know someone that will sell me one for 1500, i dont know if i want that or a b18b, for my eg hatch, the b18b has more torque and i want to go turbo so im still in debate.
Old Feb 13, 2003 | 08:54 PM
. o 69 o .'s Avatar
i would get the b17... vtec is a beautiful thing, plus it also has low compression... great for turbo
b18B vs B17a ... for what you lose in torque you gain in hp and top end. plus itr cams, Intake manifold bolt right up for some easy bolt-in power.
B17 has more potential if built right.
Old Feb 14, 2003 | 12:43 PM
performula's Avatar
Default Re: b17 (B16B)
$1500?
I'll sell you mine for $2500, 76K.
Old Feb 14, 2003 | 01:10 PM
Seye's Avatar
Default Re: b17 (performula)
why would i do that when i can get one for $1500? What are some other bolt ons that will go on a b17?
Old Feb 14, 2003 | 01:18 PM
Katman's Avatar
there's nothing 'bad' about B17A engines at all.....at least not as 'bad' as any B16A engine is. What bad things have you heard?
The B17 is a rad/rare engine.
It utilizes everything a B16A uses minus the crank & rods, which are changed to compensate for .1 liter gain. The B17 basically makes a bit more torque and some HP in comparison to a B16.
Any engine upgrades you can buy for a B16A will work on a B17A engine; they're essentially the same engine minus the fact a B17A has a different crank/rods/& pistons. if you wanna raise compression (which I suggest to do in a B17), you can easily go with some OEM B16A/Civic/or IntegraR pistons, they're all intercheangeable. Same goes for camshafts, and heads.
Old Feb 14, 2003 | 01:21 PM
Seye's Avatar
Default Re: b17 (Katman)
im thinking i want to go turbo, are they good for that? How strong is the stock bottem end?
Old Feb 14, 2003 | 03:03 PM
Katman's Avatar
ok, then you'll want to stick with the stock B17 pistons then, that is if you dont want to go aftermarket lower compression pistons. A stock B16/B17 block can handle up to aprox. 350hp (i could be a little off tho), respectively.
Old Feb 14, 2003 | 04:23 PM
Blaze45's Avatar
Brrraaaap!
most power ive ever seen from a stock b series was a B16 makin 334hp and 247ft lb of trg. dont know the mods though accept hondata.
Blaze
Old Feb 14, 2003 | 07:29 PM
Kool305's Avatar
Default Re: b17 (Blaze45)
there goes katman again with the "B17" goodies...lol...
MrPink96
Jun 25, 2005 06:00 PM
theneil
Aug 22, 2003 05:29 PM
ridestrt
Feb 17, 2003 12:46 PM
MTP04
Dec 28, 2002 08:43 PM
WuShu
May 14, 2001 03:19 PM
