B16A2 Compression (psi)
Old Mar 25, 2006 | 11:18 PM
tommy.'s Avatar
Default B16A2 Compression (psi)
doing a leak down test and wonder what specs would be for normal
Old Mar 25, 2006 | 11:27 PM
JDM_teh_WIN!!'s Avatar
Default Re: B16A2 Compression (eg6b0i)
I believe normal compression should be 250psi. 135psi is the minimum. And 29psi should be the maximum variation between cylinders.
Old Mar 27, 2006 | 11:39 AM
tommy.'s Avatar
Default Re: B16A2 Compression (JDM_teh_WIN!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">I believe normal compression should be 250psi. 135psi is the minimum. And 29psi should be the maximum variation between cylinders.</TD></TR></TABLE>
can anyone back this up?
Old Mar 27, 2006 | 02:10 PM
LSEGHATCH's Avatar
Mine are all at 195.
Old Mar 27, 2006 | 09:10 PM
so lazy's Avatar
.i work at honda and i was told by my forman that 125 is the LEAST... but my gsr is checking out at 180 and a customer's b16 read 190..
Old Mar 28, 2006 | 06:45 AM
SiBuddy00's Avatar
Default Re: B16A2 Compression (dc2-guy)
my B16A2 ran 170-185 accross the board
Old Mar 28, 2006 | 10:12 AM
Honda Bull's Avatar
Default Re: B16A2 Compression (SiBuddy00)
Which do you mean, leakdown or compression test?
185 to 190 compression is normal for a USDM B16. But every tester is different.
Old Mar 28, 2006 | 10:47 AM
NJcoupe's Avatar
Compression Ratio *17= MIN
Compression Ratio * 21.5 = MAX
Old Mar 28, 2006 | 12:31 PM
bostoncal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiBuddy00 &raquo;</TD></TR><TR><TD CLASS="quote">my B16A2 ran 170-185 accross the board</TD></TR></TABLE> same here
Mr.Integra
Apr 22, 2004 07:56 PM
Mr.Integra
Apr 22, 2004 07:55 PM
SloEG
Jul 28, 2002 06:13 AM
