B16a tranny problem...helppppp!!
Old Jun 15, 2010 | 10:19 PM
BILLisCHILL's Avatar
Default B16a tranny problem...helppppp!!
sometimes my gears wont go in. it goes in perfectly when the car is off. I got stuck at the red light many times because I cant go into first gear. If I try to shove it into first, the gears grind and the car stalls. If I turn off the car and then put it into first and then start the car, my car will shake violently and then stall. Tonight it got worst. I took it to about 4k rpm and shifted into 2nd gear and suddenly my clutch felt mushy (like no longer stiff). I have oem clutch btw. Now everytime I shift, the cluth feels like it pops and the car jolt a bit. My clutch is now completely mushy feeling and cannot get it into gear. After leaving my car alone for a while, the clutch seems to come back to normal stiffness but then it gets mushy feeling again after driving. Ive replaced my master cylinder with another used lower mileage one. I'm thinking about replacing the slave cyclinder as well. Prior to the mushy clutch tonight, the mechanic said it wasnt my clutch. He said it could be my hydrolic system or transmission cable. Can someone please help me! Its getting damn frustrating.
Old Jun 15, 2010 | 10:22 PM
Default Re: B16a tranny problem...helppppp!!
and is the mechanic right that its not a clutch problem?
Old Jun 15, 2010 | 11:16 PM
ttt
Old Jun 15, 2010 | 11:27 PM
sh!ft's Avatar
Who the fack changed my title?!
cable and hydro are different. it is your clutch
Old Jun 16, 2010 | 04:14 AM
kyden's Avatar
who is this mechanic that can't figure out if you have a cable or hydraulic clutch?
you probably have something going on with the pressure plate. loose bolts most likely.
Old Jun 16, 2010 | 11:12 AM
sh!ft's Avatar
LOL my thoughts exactly! either that or his disk is trashed
Old Jun 16, 2010 | 11:36 AM
its hydro for sure....the mechanic was a retard and didnt pop my hood to inspect. I had another mechanic tell me today that it probably isnt my clutch. So far my clutch hasnt slipped but my car does feel underpowered since this problem all started. thanks for your guys help...anyone else have a suggestion on what the problem might be?
Old Jun 16, 2010 | 11:39 AM
sh!ft's Avatar
can you step on the gas and the rpms raise and the car doesnt move any faster while driving?
Old Jun 16, 2010 | 11:44 AM
Honda Bull's Avatar
Clutch system problem. Absolutely. Primary tell-tale sign is that you can't place it in 1st while it's running, but can start the car in 1st and it stalls.
You don't even have transmission cables, so your mechanic might be retarded,... and you should probably find a new one.
EDIT: What reasons did the 2nd mechanic give for why he didn't feel it was clutch related?
Old Jun 16, 2010 | 03:07 PM
That doesnt happen. The clutch doesnt slip.
Old Jun 16, 2010 | 03:09 PM
he said he doesnt feel the clutch slipping. He said the clutch grabs but the tranny has a problem going into gear.
Old Jun 17, 2010 | 11:49 AM
i bought both brand new master and slave cylinders but dont know if its worth putting it in if that doesnt fix the problem.
Old Jun 17, 2010 | 12:26 PM
kyden's Avatar
probably not the problem.
Old Jun 17, 2010 | 01:45 PM
hondaracing84's Avatar
What it sounds like to me is that the pressure plate is not disengaging fully. If its still grabbing the disc enough while the peddle all the way down, the gears will be turning and you wont be able to go into gear. When the motor is off, the motor cant spin the shaft and it will all go into gear. Then when you start it back up and if the pressuer plate is grabbing the disc just enough while in gear, it will shake and stall. You cannot start a car in gear with the clutch engaged. It will do that. And when you try to shift into second the disc still grabbing would make it difficult to sift. It would also explain any grinds too.
Check the fork, release bearing and all the lines. Make sure the fork is not bent and seated on the pivot ball and make sure the release bearing is in good shape and seated on the fork properly. Blead the system too. If there is air it will feel mushy and not release properly. I also recemend getting a stainless steel braided clutch line too. That way you eliminate the rubber parts that can expand. Check all connections and lines for leaks.
Old Jun 17, 2010 | 08:16 PM
thanks man. ur right about the rubber line. imma look into a steel braided clutch line. Ive replaced both the master and slave cylinder but the problem still exists. taking off the tranny tmr to inspect and ive also ordered a new exedy clutch, pressure plate and throwout bearing. i will update you guys on the progress tmr.
Old Jun 17, 2010 | 09:05 PM
fredrocs's Avatar
it sounds like the springs in the clutch disc hub are either worn or have completely come out. i bought a crx that wouldn't go into gear but when i did start it in gear it would stall. i dropped the tranny to inspect the clutch and the springs came out as soon as i removed the pressure plate. the clutch disc material was still good but still had to replace the disc because of the springs.
Old Jun 18, 2010 | 10:55 AM
cracking that tranny open today...im very curious of what to find. i'll post updates
Old Jun 18, 2010 | 11:35 AM
sh!ft's Avatar
yes please post pictures of your work, im going to keep an eye on your thread just to put my .02¢ in when needed. im pretty sure honda-bull(or is it red bull? lmao) will be chiming in from time to time.
i had a guy with the same problem as you are experiencing. it ended up being the entire clutch setup. looked like some wanna be spec clutch kit and it was SEVERELY worn down. so we replaced it, re-bled the slave(s) and off it went!
Old Jun 19, 2010 | 01:11 PM
clutch disk was the problem. One of the 4 springs cracked into pieces and fell apart. So it wasnt the clutch hydrolic system (master and slave cylinder, clutch lines) nor pressure plate. There was also no meat left on the clutch disk and some burn marks on the pressure plate.
Old Jun 19, 2010 | 01:14 PM
sh!ft's Avatar
i knew it! that was my original thought(s) when you said you couldnt put it into gear when it was running. get the flywheel resurfaced and new clutch and your good to go.
hell, just for ***** and giggles, swap out the trans fluid for some honda mtf while ur at it and check the rear main seal and the seal(s) on the trans while your at it. wouldnt/couldnt hurt right?
Old Jun 19, 2010 | 07:59 PM
fredrocs's Avatar
i called it! by the way how were the flywheel bolts? mine were damaged and had a hell of a hard time tryna get those 12 pt. bolts off.,
Old Jun 19, 2010 | 10:58 PM
i changed everything. got an exedy oem replacement clutch kit for $160. thought it was a good so why not do everything. the flywheel bolts were actually in perfect condition. what many ppl first told me was that it was my hydrolic system or pressure plate. turns out it was the clutch the whole time. i hope this thread helps everyone.
Old Jun 20, 2010 | 12:27 AM
sh!ft's Avatar
i (as well as many other ppl) hope you learned something(s) from this
Old Jun 20, 2010 | 09:37 AM
most definitely
Old Jun 21, 2010 | 07:48 PM
fredrocs's Avatar
that clutch disc is worn down pretty good! the reason why your mechanic didn't suspect the clutch is because he prolly did a slip test and it passes because that spring that popped off was acting like an engaged clutch locking up the engine and trans! but good for you, i'm glad u got that all figured out! how's it running now?
MugenGTR
Jan 29, 2012 02:14 PM
codybb4
Dec 9, 2008 08:44 AM
Agito
Aug 26, 2006 12:09 PM
explorerx7
Jun 27, 2005 03:47 PM
95hbMatt
Jun 22, 2003 10:03 AM
