b16a with ctr piston ?????
Old Oct 25, 2004 | 06:54 PM
EK9Greg's Avatar
Default b16a with ctr piston ?????
I have a b16a block and I want to put CTR standard size pistons in the block I want to know what all do I have to use to do this. What rods. crank stuff like that. Yes I have searched for info in this but mostly over sides pistons are used. Any help me out. THANX
I also want to use a ctr LSD is it hard to do. I've never touched a tranny before. Or should I just take it somewhere
Old Oct 25, 2004 | 07:32 PM
anothersickhatch's Avatar
Default Re: b16a with ctr piston ????? (EK9Greg)
you use your stock rods and crank...the only modification that you need is you need to have a machine shop machine both small hole sides of the rods in order to fit those ctr pistons.
while you have the bottom end apart, you might as well get new rod and main bearings and have everything balanced.
im sure it would be a bitch to add a ctr lsd to a b16 tranny. it would be kind of expensive also. you are better off just buying a used type-r tranny, integra or civic.
Old Oct 25, 2004 | 08:56 PM
93lsd's Avatar
yea, while everthing is apart i would deff get everything balanced, so you don't beat up the bearings.
Master23
Feb 15, 2006 08:56 AM
black-hatch
Jan 30, 2003 08:16 AM
2 litre EG
Apr 16, 2002 10:53 AM
