B16 Tranny
Old Jun 20, 2007 | 11:17 PM
White_EK49's Avatar
Default B16 Tranny
I replace the sychros hub on the B16 with some parts I had laying around. Wanted to know if GSR/ITR parts are interchangeable to the 99 B16. This was on the mainshaft, not the counter shaft. After I assemble it and tried to close the case, it did not want to go down. I even tried using different casing, no luck. Any one have some experience in this tranny stuff. Please shed some light.
Old Jun 21, 2007 | 02:49 AM
92_VX_EG's Avatar
Default Re: B16 Tranny (White_EK49)
Synchros and synchro hubs are all interchangeable as long as they're for the same gears... you can't use a 5th gear on a 3rd etc... Are you sure all the shifter rods lined up? There's another hole in the case for where the shifter mechanism is and it's hard to line up. I had to mess with mine where the shift-linkage pin goes, move it back and forth, and turned it. My case went right back on... it didn't want to go on at first.
Old Jun 21, 2007 | 10:25 PM
White_EK49's Avatar
Default Re: B16 Tranny (92_VX_EG)
I have tried for an hour straight to put this case back on. I am not sure if the rods are lined up correctly. Is there another secret to this madness of just putting a case on. I have done at least 10. This is the first.
Old Jun 21, 2007 | 11:37 PM
dude_123's Avatar
If all the rods are lined up in the holes it should just slide into place with a few shake of the case. Make sure you placed the correct rods onto the hubs too.
Old Jun 24, 2007 | 12:29 AM
White_EK49's Avatar
Default Re: B16 Tranny (dude_123)
still nothing. wierd cause its the same shift fork and same everything esle. what am i doing wrong. if it doesnt go in, i am going to sell it.
Old Jun 25, 2007 | 09:29 PM
moehp's Avatar
check your gear stacks. sounds like you have a hub on upside down or something elese making it too tall to close the case.
Old Jun 27, 2007 | 06:29 PM
White_EK49's Avatar
Default Re: B16 Tranny (moehp)
Thanks so much, it was that indeed. I can buy you beer!!!!
Old Jun 27, 2007 | 11:12 PM
slowcivic2k's Avatar
Another problem that people have that are first time rebuilders are they forget to align the brake stopper ring on the end of the mainshaft, it has a tab that sticks out and will prevent the case from sliding down all the way as well.
Might as well post it here in case someone that actually knows how to search can get this bit as well...
Old Jun 28, 2007 | 07:37 PM
White_EK49's Avatar
Default Re: B16 Tranny (slowcivic2k)
what are you talking about brake stopper rings. you mean the two washer at the bottom of the mainshaft. Or is it attached to the mainshaft.
Old Jun 28, 2007 | 08:02 PM
The brake stopper ring is a circular piece with a tab that sticks out from the shaft, it is directly below the mainshaft bearing.....
Old Jun 29, 2007 | 07:45 PM
White_EK49's Avatar
okay, no, i know how to align that before the casing goes on. You are right about that though. Good Point
excoupeb20jdm
Feb 16, 2015 08:17 PM
Darkseid
Jul 12, 2006 11:07 PM
dahoopdahup
Mar 14, 2006 12:43 PM
Race Egr
May 1, 2004 08:50 AM
SupaFly_Honda
Oct 8, 2003 11:11 PM
