b16 conversion
Old Jan 30, 2006 | 01:48 PM
wullie_vtec's Avatar
Default b16 conversion
i recently converted my d16z6 eg civic to b16a2and didnt change the loom i have been told there is a few wires difernt if so does anyone no were they go from and to
Old Jan 30, 2006 | 01:54 PM
devnull's Avatar
Have to add knock sensor (1 wire). That's pretty much it. You might have to extend VTEC and water temp and Oil pressure. Also if your injector clips don't go right in, just use your D16Z6 injectors. They are the same exact size, same damn part no# too.
Old Jan 30, 2006 | 02:01 PM
Default Re: (badboypolar2)
the injectors cliped on fine but how do i do the rest
Old Jan 30, 2006 | 02:10 PM
devnull's Avatar
Knock sensor has to be added. It is a single pin connector. Alot of people just chip their ecu's to run without it. If you add it you need to run a single wire from the knock which is on back of the engine near the oil pressure sensor and run it into the car where the ECU is. As far as the rest if the connector does not plug into the sensor then cut it with about 5 inchs of spare wire before the clip or half way inbetween the connector clip and where the wire joins the rest of the engine harness then strip about 1/4 inch and solder it to a wire that lengthens the wire enough to connect the clip to the sensor. Not to much but not to little either.
Old Jan 30, 2006 | 02:23 PM
where on the ecu or round the ecu does the wire go thnx :thumbup
Old Jan 30, 2006 | 02:36 PM
devnull's Avatar
Not exact but close enough.
https://honda-tech.com/zerothread?id=644434
Old Jan 30, 2006 | 03:27 PM
do i change the three wires in that link as it is a p30 ecu on my car
Old Jan 30, 2006 | 04:01 PM
devnull's Avatar
If you are talking about the P72 and Butterfly valves then no.
Old Jan 31, 2006 | 02:04 PM
sorry about this i had someone else try to run the wire but they dont get where the wire goes could you please tell me where it goes to please
Old Feb 21, 2006 | 09:55 PM
civicracer94's Avatar
think this is what hes asking
run a wire from the knock sensor to the ecu you want to run it to d3 on the ecu
Old Feb 21, 2006 | 10:15 PM
Default Re: (civicracer94)
also dont forget if you are useing the d16z6 harness you have to cut and extend the 4 wires for your o2 sensor (so they reach to the o2 in the rear now) other then that and the knock sensor thats it
Chimera
12
Dec 24, 2018 03:14 PM
highflyinhonda
Jun 3, 2007 05:26 PM
nub_pwn
Nov 18, 2006 11:48 PM
stillrockin18s
Jul 21, 2005 12:13 AM
hj
Oct 29, 2003 04:40 PM
