B&M Trick shift Synthetic ATF
Anyone tried this? I was at PepBoys and wanted to get synthetic ATF, this was $1 cheaper than Mobil 1. I am going to put it in tomorrow. Just wanted to know if anyone had any problems with it.
Thanks
Thanks
Dont do it. Honda auto trannies are already sensitive enough, I think you're asking for trouble it you do it There are friction enhancers in trick shift. Its basically old chool ford atf. There are coarse particals in the fluid I dont think the outcome will be good.
just wondering if anyone else has tried it... i bought some but haven't used it after reading this post... I just wanted to know if it was worth my time or not... thanks for any help
i wouldnt put anything other than Honda ATF into an automatic honda trans, like Texan said, pretty good for a GM but i wouldnt know how it would act in a honda trans.
I bought some of the B&M synthetic when I was redoing my CV boot and then chickened out after reading this thread. The synthetic is different than the conventional, the conventional is type F, but the synthetic meets DexronIII and Mercon, but I don't want to be a guinea pig. Maybe I'll run it at the track, and next day change to normal. It's easy and cheap enough.
