Crankshaft pulley puller
Old Nov 17, 2002 | 05:03 PM
tilt's Avatar
Default Crankshaft pulley puller
I just got the crankshaft bolt off of a crx, but now I cant get the crankshaft pulley off. I'd like to know what is the best way to pull it off? a jaw puller? from where and what size? I'm just afraid i might damage it if i try prying too hard.
Old Nov 18, 2002 | 02:16 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Crankshaft pulley puller (tilt)
2 hands is all you need.......grab and wiggle..........
Old Nov 18, 2002 | 05:29 AM
brian b's Avatar
New User
Default Re: Crankshaft pulley puller (Mista Bone)
Right, the crank pulley is not pressed onto the shaft.. it may be slightly seized on there from time but it will come off
Old Nov 18, 2002 | 05:32 AM
b19coupe's Avatar
Don't pry-you will damage it. Soak it in WD40 or penetrating oil if it gives you a lot of trouble. Like Mista Bone says "grab and wiggle" with two hands 180 degrees apart.
Old Nov 18, 2002 | 08:06 AM
tilt's Avatar
Default Re: Crankshaft pulley puller (b19coupe)
thanks guys. it came right off
BLKFLSH
Apr 10, 2011 01:54 PM
bdiz
Nov 25, 2009 02:05 PM
griz50cal
16
Jan 29, 2007 05:50 AM
SuicideSlide
Oct 9, 2004 08:27 AM
Dan GSR
May 8, 2003 06:52 AM
