Help with auto transmission
Old Mar 25, 2006 | 06:16 AM
8Si8's Avatar
Default Help with auto transmission
I just bought a 98 acura 2.3CL with only 70,000 miles and it started to shift hard. I read in the owners manual that not using Honda ATF then it can cause shift problems. I have no way of knowing if the previous owner used Honda ATF, so I was wondering if the Honda fluid is maybe a different color? Right now it has plenty of fluid and it is a light red color. Any help with this would be great, thanks.
Frank
Old Mar 25, 2006 | 08:42 AM
slomofo's Avatar
GDD Member
Honda auto transmissions suck, mostly accord transmissions from 90-02 start hard shifting, then not down shifting, then not moving forward later on down the road.
Go ahead and do the Honda ATF, i'm sure it won't work, but it's worth a shot.
Old Mar 27, 2006 | 12:36 PM
B18C1EM1's Avatar
did u check to see how much fluid you have in the trans low fluid can cause all types of problems
regular_guy_49
Sep 18, 2017 09:27 AM
Cropgun
Feb 28, 2017 08:56 AM
chardwick
Nov 4, 2006 07:15 AM
JMD
May 11, 2003 02:42 PM
RaceTilIDie
Nov 18, 2002 06:55 AM
