Axles - inner joint difference?
Re: Axles - inner joint difference? (-TJ)
So, no one has ever thought to compare the right side inner joint between 90-93 and 94+ integra?
Re: Axles - inner joint difference? (driveshaftshop)
'99-00 are a very different design internally. Also, the early joints use short cups and have two different diameters for the bearing pegs...leading to broken axles and sometimes trans cases, too if the axle is just a little short. We replace the short cups with the later deep ones (JDM cups are deep even on the early B16s). Hope that helps.
DEVIN22CBR
06-25-2003 08:00 PM
