axle / transmission noise and problem
Old Aug 23, 2004 | 09:39 AM
18gsir's Avatar
Default axle / transmission noise and problem(diagnosed)
yesterday, i did a 2nd gear pull to redline and let off. then the car started to shake and make clunking noise as i slowed down. the noise and shake happens faster as the speed goes up. doesnt matter im turning or not. so i jacked the car up and spun the wheels by hand and noticed the driver side inner axle would move in and out of the transmission bout 5mm. it would move with the outter axle along with the center support bearing. so i think somthing is pushing the shaft from the diff area. after work today i will take the axle out and see WTF is going on in there. as for now i would like to see if anybody ahs any ideas as for what is up with my tranny/ axle. also the jobber axles are about 2 months old and dont click due to worn out bearings.
here is my partial setup:
1999 civic sir(canada)
greddy turbo kit 9psi
jobber axles
quaife LSD
centerforce dual friction clutch
kumho 712 tires
stock tranny besides the lsd
Modified by 18gsir at 2:25 AM 8/24/2004
Old Aug 23, 2004 | 11:17 AM
Gearspeed-Performance's Avatar
Default Re: axle / transmission noise and problem (18gsir)
It can be either an axle or possibly a blown diff bearing. Check the trans fluid for contamination.
Old Aug 23, 2004 | 05:23 PM
18gsir's Avatar
Default Re: axle / transmission noise and problem (GearSpeedEF9)
yup youre right, its a bent driver side axle. its bent inside the cup thingy. i have a pic but dunno how to post it. hopefully this axle has warranty
gotta get me some gator axles
Old Aug 24, 2004 | 07:52 AM
We use driveshaft shop. You can give them a call and ask for Frank<<<cool dude.
Old May 18, 2005 | 01:28 PM
thrty8street's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gsir &raquo;</TD></TR><TR><TD CLASS="quote">yup youre right, its a bent driver side axle. its bent inside the cup thingy. i have a pic but dunno how to post it. hopefully this axle has warranty
gotta get me some gator axles</TD></TR></TABLE>
what do you mean bent? how could it be bent?
I just finished replacing my clutch and this sound appeared.
I got the same problem, noise comes from the drivers side axle, flywheel area. its like a clunk clunk clunk sounds when it starts to move only. you cant hear it in neutral. I just finished replacing my clutch and this sound appeared.
I jacked the car up and rotated the passenger and drivers wheel and the sound only came when i rotated the drivers and i went under the car so i know the sound is either the axle or in the flywheel area.
Old May 19, 2005 | 05:08 AM
Default Re: axle / transmission noise and problem (thrty8street)
up
EG civic
Apr 1, 2007 09:35 AM
XX Boosted Si XX
Jun 27, 2006 04:48 AM
ih8sndq
Dec 24, 2004 03:17 AM
bocian
May 18, 2003 10:59 PM
hybrid901
Jun 4, 2002 01:46 PM
