Quaffe broken axle?
Old May 28, 2002 | 04:24 PM
hybrid901's Avatar
Default Quaffe broken axle?
I have broke 8 or 9 axles in the past month and I'm trying to see if it can be anything besides just needing to get some DDS 3 axles. Its always the driver side also. My car makes a slight noise when turning right and it totally goes away when turning left. I really cannot describe the noise but when turning l I can fell it also. I know not much help. I broke a axle once and had to drive home about 65 miles could this have burt the quaffe? If there any test I can do to see if its anything besides the axle causing this problem? Also when I'm coasting down the street the car goes straight but as soon as I give it gas it pulls to the left hard. Any help?
Old May 28, 2002 | 07:11 PM
iceburgslim's Avatar
Default Re: Quaffe broken axle? (hybrid901)
The LSD is causing the noise, because the drivers side axle was not designed to have any significant power applied to it, so the noise is the reslut. I do not know anything more about the specifics, but someone I know has had this problem.
Old May 28, 2002 | 07:14 PM
hybrid901's Avatar
So is the LSD messed up? Did I break it driving on a broken axle? I was driving tonight and its more of a humming sound. The sound doesn't change if I'm in gear or not. So do I just need stronger axles? When I swapped in this new axle the noise got quieter but was still there but it came back just as loud after 2 days.
Old May 28, 2002 | 07:20 PM
*Boostwerks*'s Avatar
Sounds definetly like the LSD is messed up. It might be a gear that got stripped(?) and is now sending power to only one wheel.
That kind of problem shouldn't be the axles.
Old May 28, 2002 | 07:30 PM
hybrid901's Avatar
Default Re: Quaffe broken axle? (Bryson)
it still does 2 wheel burnouts at the track. Has anyone had this problem before?
Old May 28, 2002 | 07:35 PM
I really don't see how it would pull to the left then if it still does 2 wheel burn outs?
m
Old May 28, 2002 | 07:43 PM
paulzy's Avatar
humming? have you checked your wheel bearings?
Old May 28, 2002 | 07:58 PM
hybrid901's Avatar
Default Re: Quaffe broken axle? (Slow_ass_4dr)
We put it on the lift today and there was no play with the wheel from side to side. Should I go ahead and change them out anyways? Can wheel bearing cause a humming sound or make the car pull? I just hope its not the quaffe.
Old May 28, 2002 | 08:04 PM
kidkutz's Avatar
what's the big deal if it's the quaife? i love my quaife they're life time warrantied!
Old May 28, 2002 | 08:06 PM
A wheel berring will make a "grouling" sound and get louder(or change pitch) as the car gets faster.
Old May 28, 2002 | 08:24 PM
hybrid901's Avatar
I love my quaife also but I like it best in my tranny. I don't fell like taking my tranny apart so soon its only been in my tranny for 4000 miles. Can the wheel bearing be bad even if I cannot shake my wheel when my car is lifted up?
Old May 28, 2002 | 08:28 PM
Pengo's Avatar
not sure about ur car pulling to one side or breaking the axle, but as for the sound, could possibly be worn or damaged CV joint. the most obvious thing to check woudl be damage on the boot, but u said u already looked at the car while it was up rite?
anyway, i know when i had a damaged cv on my old car it was only messed up on one side and only made a sound when i made one turn and not another. dont remember if it pulled to one side or another tho.
if your burning out with both tires, i cant see how it could be pulling harder on one side than the other tho...
Old May 28, 2002 | 08:35 PM
rice4life's Avatar
what car and engine do you have, maybe you dont have the right axles combination. when i did my b16 swap into my crx, i didn't use the right axles on the driver side and my axles were binding. just wondering because your s/n is hybrid901
Old May 28, 2002 | 08:49 PM
hybrid901's Avatar
Default Re: Quaffe broken axle? (rice4life)
I have a b18c1 in a 93 si. My axles were fine for the 35000 miles until I turned the boost up now its driving my crazy.
Old May 29, 2002 | 08:07 AM
hybrid901's Avatar
up
Old May 29, 2002 | 12:23 PM
sushibug's Avatar
i broke a cv joint the first week of having my turbo in. i didnt notice it until i came to get my downpipe fixed. now my car needs an allignment because it keeps drifting to the right.
Old Jun 4, 2002 | 01:46 PM
roadracr's Avatar
hybrid901,
My guess is you didn't have the diff installed by an experienced diff man and the gear clearances are off enough to cause premature wear. If you want to determine if this is it or not you could take it to a local trans shop and they'll estimate it for free (hopefully with an opinion of what it is) or you could just change the trans fluid. Changing the trans fluid won't fix the gear clearance problem but it should temporarily quite it down which will let you know it's the clearances in the transaxle. With clearance problems, the exessive friction causes the transaxle fluid/oil to rapidly degrade and it collects all the metal shavings which just adds to the wear problem. I haven't heard your noise but I know the noise. Also, your transaxle should be getting unusually hot after about 10 minutes of regular driving.
Anyway, hope it all works out for you.
dtran002
Feb 22, 2013 11:48 AM
astig* DC2
Sep 20, 2005 12:23 PM
18gsir
May 19, 2005 05:08 AM
ih8sndq
Dec 24, 2004 03:17 AM
B18C-RnVA
Feb 25, 2002 08:30 PM
